I plan to mill an intricate part )miniature 4" long cello neck) from maple with four operations at 90 degree indexes on my tormach 770.
I'm cutting some fat off all sides and then shaping the intricate curvy form
Do you think it would be more accurate to use a vise and rotate the wood block 4 times (the area I cut would be off to the side of the vise) or is it more accurate to use a tormach 6in 4th axis with four jaw chuck because this would only require the wood to be clamped once? Any thoughts??
