584,829 active members*
4,783 visitors online*
IndustryArena Forum > CAM Software > Alphacam > DAHLIH DMX-320 5 Axis Post
Results 1 to 2 of 2
    Jul 2016
    3
    I'm hoping someone can help, I have modified a post for our DAHLIH DMX 320 5 Axis Mill with Fanuc OiMf control, but anything that is programmed in the flat plane (or any plane that is on X0 Y0 is outputted at C-90. rather than C0. , can anyone point me in the right direction to fix this? any other plane outputs correctly.
    It is also outputting a tool preselect of T0 after the last tool is called, I cant find out how to change this to output the first tool?
    Regards
    Larry
    Apr 2010
    89
    Re: DAHLIH DMX-320 5 Axis Post
    It seems your Post is always outputting C as C[WAC-90] and since WAC is 0 on the XY Plane it will always output as -90 with that code.
    You can do something similar to the following code
    $IF WVF = 0 '' XY Plane.
    G0 C[WAC]
    $ELSE
    G0 C[WAC-90] '' All Other Planes.
    $ENDIF
    Just be careful where you put this in the Post as you can't place an $IF statement inside another $IF statment in these old stylle non VBA Posts.
    Use T[T(1)] to call first tool used, the following code is what I use to place the first tool used back in the spindle at the end of the Heidenhain ISO program when more than one tool is used.
    $IF NMT = 1
    N[N] Y+0 M91
    $ELSE
    N[N] Y+0 M91
    N[N] G07 M06
    N[N] T[T(1)] G17 S[FIRST_TOOL_RPM]
    $ENDIF
    Cheers.
  1. All about the cnc DAHLIH
    By cnc_swe in forum Uncategorised MetalWorking Machines
    Last Post: 09-25-2015, 06:02 AM
  2. Dahlih CNC Machine
    By w102acd in forum Uncategorised MetalWorking Machines
    Last Post: 10-05-2009, 01:55 PM
  3. Fanuc 10M on Dahlih MCV 760.
    By Jakes in forum Fanuc
    Last Post: 01-28-2009, 10:06 PM
  4. Dahlih
    By miggo in forum Fanuc
    Last Post: 01-08-2009, 11:46 AM
  5. Dahlih
    Last Post: 12-15-2008, 08:00 AM
