585,997 active members*
5,120 visitors online*
    Feb 2012
    52
    Question BOB for a new smoothstepper
    G'day all, I bought a new usb smoothstepper board (SS-01) from Homanns & the manual isn't clear, I'm still unsure if I need to add a fourth breakout board. I have the small BOB's in the DB9 plugs from the Gecko 540 to the motors, do I need to add another BOB somewhere? thanks, Rob.
    Nov 2012
    108
    Re: BOB for a new smoothstepper
    I'm not quite sure what you are asking -- the DB9 connectors on your G540 go to your stepper motors -- up to 4 if you have a four axis machine.
    (I just have wires soldered to DB9 plugs -- I don't use any breakout board there)
    If you have limit switches or a touch sensor you may want another connector on the box you have your G540 and power supply installed in -- have you read http://www.homanndesigns.com/pdfs/EN010_V8.pdf ?
    Feb 2012
    52
    Thanks for the reply tgdavies, you need to look at the manual http://warp9td.com/documentation/Smo...ManualV1.0.pdf to see why there's some confusion. I've seen your link...I know it well but it doesn't show a smoothstepper. Really I was just confirming the (DB9) BoB's were enough. Nice to be re-assured every now & then. Thanks
  1. Smoothstepper
    By Gallchobhair in forum Stepper Motors / Drives
    Last Post: 10-30-2013, 12:37 AM
  2. SmoothStepper
    By jakemestre in forum Tormach Personal CNC Mill
    Last Post: 08-27-2012, 02:41 AM
  3. Smoothstepper for CNC?
    By Litemover in forum DIY CNC Router Table Machines
    Last Post: 07-15-2012, 06:34 PM
  4. What next, should i try the Smoothstepper?
    By sylvester1073 in forum Controller & Computer Solutions
    Last Post: 08-01-2010, 10:32 AM
  5. Anyone tried a Smoothstepper?
    By Ranscon in forum CNC Machine Related Electronics
    Last Post: 03-07-2009, 07:37 PM
