585,992 active members*
5,610 visitors online*
Thread: backup
    Dec 2011
    4
    backup
    Hi how do back up your parameters on a 1997 Colchester Tornado 100.
    May 2016
    526
    Re: backup
    Step 1: Set up your Personal Computer (PC) or laptop to receive data. (click here for information on RS232 setup)
    Step 2: Punch out NC Parameters as follow
    Select EDIT mode.
    Select PARAMETER screen (by pressing PARAM/DGNOS key once).
    Press and hold EOB key while pressing OUTPUT START.
    * Note: OUTPUT will flash in the lower right-hand corner and NC parameters will be output.
    Step 3: Punch out PMC Parameters as follow
    Select EDIT mode.
    Select DIAGNOSTICS screen (by pressing PARAM/DGNOS key twice).
    Press OUTPUT START.
    Step 4: Punch out all NC Programs as follow
    Make sure parameter no. 10 bit#4 = 0 (unprotect programs 9000 ~ 9999)
    Select EDIT mode.
    Select PROGRAM Memory screen.
    Key in “O-9999”.
    Press OUTPUT START.
    Step 5: Punch out Offsets as follow
    Select EDIT mode.
    Select OFFSET screen.
    Press OUTPUT START.
  1. battery backup
    By Daniel Boone in forum Fadal
    Last Post: 10-03-2012, 06:17 AM
  2. Backup on contour
    By Pete_B in forum CamSoft Products
    Last Post: 08-20-2012, 10:40 AM
  3. BP VMC Backup
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2012, 01:23 PM
  4. How do you backup your config.
    By CATCH22 in forum Mach Mill
    Last Post: 12-21-2007, 04:13 AM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
