584,850 active members*
4,361 visitors online*
Thread: Concrete VMC
Page 1 of 16 12311
Results 1 to 20 of 305
    May 2016
    108
    Concrete VMC
    Hello my name is Stef, I already make some posts on this forum. I have converted an bf25 (g0704) to cnc and used it now for about a year. Right now I want something bigger and more rigid.
    http://www.cnczone.com/forums/bencht...22688-cnc.html
    After a while of gathering parts and looking to different designs. I have start building yesterday right now the x axis is starting to get shape.
    The x axis is made out of steel, the base and column will be made of concrete (uhpc) Travels will be X600 Y300 Z550. It will have an BT30 spindel with a 16 position tool changer on top.
    I will use leadshine closed loop steppers to drive all the axis and use a USBCNC control board to control everything.
    will keep you guys updated.
    stef
    Aug 2005
    129
    Re: Concrete VMC
    Sweet!
    Andrew
    Andrew Abken
    www.drewtronics.net - PCB Cutters
    Jan 2008
    1523
    Re: Concrete VMC
    Is that laser cut steel?
    Looks very nice so far
    May 2016
    108
    Re: Concrete VMC
    yes 8mm laser cutted steel, with 60x30mm steel bars on top. Everything now needs to be welded after that it will be stress relived and then all the mounting surfaces will be milled.
    stef
    May 2011
    790
    Re: Concrete VMC
    Your workmanship is top notch. Any factory would be proud of a product that looks like that.
    Have you already done all of the performance math for speed, acceleration, available cutting force?
    I'm working on a spreadsheet for my own build. To try and determine the best pitch of ballscrew to use for the motors I have, and to account for possible future upgrades, including the effects of ballscrew and motor inertia. I've already been playing with this for rack and pinion. I'm curious if anyone else has done this that I can compare notes with.
    Mar 2004
    1306
    Re: Concrete VMC
    Great start to the show. Subscribed and getting popcorn
    Mark
    Regards,
    Mark
    May 2016
    108
    Re: Concrete VMC
    Small update nothing big. Machined the steel strips that will hold the motor and end bearing. Also made two aloy strips that hold everything together so makes it easier to weld.
    There is no math behind this machine, just looking to other machines and looking what feels right. I am still thinking what to do with the motors, using closed loop steppers or using servo's.
    I think closed loop steppers are good enough but with servo's i can get higher speeds if i want. How do you guys think about closed loop steppers vs servo's.
    used a nema38 8nm closed loop stepper from my current cnc to test fit.
    Stef
    May 2011
    790
    Re: Concrete VMC
    Quote Originally Posted by stef110 View Post
    It really depends on what you want to accomplish. You have fairly small travels, so what speeds do you want to achieve? You will be limited by the critical speed of your longest screw for maximum speed. It doesn't really matter what kind of motor you have beyond that. What speed do you want?
    Also, acceleration is an issue that will affect your performance, and your machine does not look light. Do you want a speed demon, or what are you happy with? Are there two screws for the bottom tier? I see holes where two screws could go....but that would put those screws out in the open? And you have put alot of work into protecting the top screw from debris, so I don't know what you have planned.......
    What kind of HP will your spindle be capable of? For a machine like this, I assume it's a big one. And I assume that this is for metal work. Your cutting forces could be several hundred pounds if you have a huge spindle cutting metal, and that is not a trivial amount, as it can be for a home made wood router.
    For my own build, I was a little bit surprised to see what kinds of differences there were between 5mm and 10mm pitch. It made a huge difference.
    To answer your question, really, I'd need to know the specifics, such as,
    What is the weight of that big piece you made, including the table, and including the largest work piece you might put on it, and including all of the bits, like the ballscrew and motor? Everything that would be moving back and forth.
    Where is the torque graph for the stepper you want to use, using the appropriate power supply and microstepping? What is the motor inertia for the motor? What are the diameter (s) pitch and length of the screw that is not yet shown but will be used to move the big piece you have shown back and forth?
    What kind of servo are you thinking of, or are you looking for recommendations?
    What are your goals for acceleration (in G's) and top speed (in IPM)?
    What kind of HP spindle are you planning on? Do you know what the cutting forces might be? Easy enough to run some hypothetical numbers through a feeds and speeds calculator to see what the forces are if you know what kind of HP is available.
    Dec 2007
    379
    Re: Concrete VMC
    Oh man that is a beast. No steppers for that thing...
    May 2016
    108
    Re: Concrete VMC
    Thanks NIC for the help.
    Here is a picture off the current design base and column are still "subject to change".
    The weight of the table will be 50Kg think that there will be a max of 100kg on the table so for the X axis there will be 150Kg load.
    For the Y axis there will be 260kg load when there is 100Kg on the table.
    The x axis spindle is a 2005 and is 850mm long
    Y axis spindle will also be 2005 and is around 500mm long
    Here are the specs of the closed loop stepper i want to use right now:
    http://www.leadshine.com/UploadFile/Down/ES-Md_V1.3.pdf I will use model ES-M23480
    Will supply them with 72v and the controllers on current machine are set to a micro step of 1600.
    I was also looking into these kind of servo's DMM | NEW DYN2 AC Servo Drive | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER and then the nema34 equivalent. So a 0.75Kw version.
    For the spindle power i not yet decided, I am looking for a big servo motor because i need an indexer to led the spindel stop every time on the same spot because of the tool changer.
    Thinking somewhere around 3Kw will be fine. Right now i have a 1.1KW motor with a 2:1 acceleration on it to a chief 6000rpm with a 3000rpm ac motor. And for aluminium i have enough power.
    I don't have the idea of cutting steels with this new machine. I normally only work with alloy but if possible it will be a nice feature.
    Right now i a chief speeds of 4000mm/m with nema24's 3nm and 1605 spindles faster would be nice but have no idea how fast it needs to be.
    sorry for the messy answer but i hope you right now have a feeling of what i am planning of.
    stef
    Aug 2004
    780
    Re: Concrete VMC
    Nice start !
    My advice is servos, absolutely, for the accuracy and acceleration, both very important.
    For any 3D milling work, mostly acceleration is the defining parameter, top speed is pretty unimportant.
    Servos tend to accelerate and run real-world 3-5x faster than steppers, on complex work, ie other than box shapes.
    Fwiw .. I never use the top speed of my servos, and limit the machine speed to about 20-40% of max.
    And I use speed-rate override.
    On a lathe with 18 cm / 40 cm travels, position-to-crash is about 1 sec at top speed.
    Math:
    10 ms to accelerate to top speed- 3000 rpm, = 60 revolutions/sec. (I also use much less than max accceleration. Too Jerky.)
    1500 rpm at screw, 30 r/sec.
    Screw = 4 mm /turn, 120 mm / sec.
    1.5 secs end-end on x, typically about 0.75 secs.
    And about 1 second on typical Z axis positioning, near the chuck.
    Lathe is 12x24" light industrial.
    I suspect You will need
    May 2011
    790
    Re: Concrete VMC
    Are those 15mm bearing end supports? I have a similar set up for supports and mounts, but I'm right now deciding on what pitch screws to buy. I was thinking 25mm OD, but now I think 20mm OD would be better. I'm not sure I can use 15mm ID bearings because of the screw depth? But it looks like you've done it. Are those 15mm ID bearings with the 20mm screw and how did that work out for you?
    I used the graph at the bottom of page 8. I didn't bother trying to figure out what they were saying about the holding torque percentage in the software manual. I just used that graph. Interesting, this stepper goes to 2400 RPM.
    Also, how fast do you want to spin your ballscrews at? I limited you to 2878 RPM for a length of 850mm according to the critical speed calculator from Nook. The NCalculators critical speed is much higher than the Nook one, I think Nook takes a percentage of theoretical to be on the safe side. But spinning a ball screw at 2878 RPM seems excessively fast to me already.
    I just did the calculations for the bottom screw that you said is 500mm, pushing 260kg, although I did limit the speed based on the 850mm length.
    So here is what my spreadsheet is saying. Does not include bearing friction. Not liable for errors in math, which may exist. It would be nice if someone else could do some math independently from me to verify or contradict my results. You might need to save the first one and then zoom in on it to see each graph.
    Attachment 364072
    Attachment 364074
    Attachment 364076
    If I had the cash I would use those DMM Nema 34 size 0.75KW on my own build. The graph shows peak output only, not continuous. I don't know what percentage of the time you can run at peak output?
    The 10mm pitch would be better I think. Actually, I think the ideal might be a 2525 driven by a servo with a gear reducer. Of course, your travels are small, so that's overkill. I don't think I can afford that on my own build. For myself, I'm torn between trying to find some 3:1 reducers and using a 2525 with my nema34s or just using 2010 or 2510 with my 15mm bearing end supports.
    Also, this doesn't include limitations in force and speed that may exist in your bearings, etc. I don't know what those are.
    May 2011
    790
    Re: Concrete VMC
    This is a video I found on YouTube. It's not my video, nor am I affiliated in any way with the person who made it. I just really like this video.
    He says it's "no name chinese 400w 60v servo motor, and drive is granite device ioni pro HC on video I have 15m/min and 0,5g but I can reach up to 30m/min and 1g"
    I think he's using 10mm pitch ballscrews with some belt driven gear reduction from the servos.
    May 2016
    108
    Re: Concrete VMC
    thanks for the calculations. I have ordered a 750watt delta servo motor with drive. it is a 80mm side instead of an 86 size nema34.
    https://www.aliexpress.com/item/80mm...326080829.html
    I just gone test how it will preform on the X axis with a 5mm spindle. before i order the rest of the spindles.
    Stef
    May 2011
    790
    Re: Concrete VMC
    Stef
    Ah, OK. I just assumed that the motor mount you have is for a Nema 34 as it looks about the same as the ones I have for my build. If I had the cash I would use the DMM 750W servo that has the same frame size as the Nema 34 so I could use the same mounts that I already have.
    You'd definitely be better off with the 10mm pitch IMO, especially if using a Nema 34, but since you're using servos now, as long as you're happy with the top speed you can get, then it doesn't matter. The axis you're building now has the longer screw, so your tests should tell you what that is.
    I really don't know what percentage of the time you can run over the continuous power rating though, and that is something I wonder about.
    Looking forward to seeing this thing when it is complete!
    Apr 2009
    5516
    Re: Concrete VMC
    Quote Originally Posted by NIC 77 View Post
    In the intermittent zone (IZ) maybe 3-5 seconds. 5mm pitch screw on a VMC is pretty common.
    Apr 2006
    169
    Re: Concrete VMC
    i copied the quotation from NIC 77
    also for BF25 cnc mill conversion
    :cheers:
    May 2016
    108
    Re: Concrete VMC
    last 2 days are spent on welding the frame, after some welding took a break to let the thing cool down a bit. Next step will be heat treading.
    stef
    May 2011
    790
    Re: Concrete VMC
    I'm quite jealous of the awesome looking stuff you're making. Keep up the good work.
    May 2016
    108
    Re: Concrete VMC
    Not much progress to announce, frame is right now at the heat treading company and have to wait till i get it back.
    Mean while i received my delta servo motor and drive and it looks quite nice!
    This weekend started a new awsome project i just wanted to share with you guys.
    We are building a 1.5kg combat robot. The main frame is milled out of a 3.5kg chunk of 7075 alloy. And milled down to a frame of 258 gram.
    Frame is milled on my current g0704 mill and took about 12 to 14 hours including making cam, clamping and dialing in.
    More pictures and updates on our facebook page : https://www.facebook.com/metalskullrobotics/
    Stef
Page 1 of 16 12311
  1. Using concrete as a fixture
    By GITRDUN in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-30-2015, 09:17 PM
  2. Concrete Stamp....
    By AussieGecko in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2013, 01:25 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. Concrete Lathe
    By tusavision in forum Linear and Rotary Motion
    Last Post: 01-18-2010, 01:26 AM
  5. Polymer Concrete
    By ericdwilso in forum Vertical Mill, Lathe Project Log
    Last Post: 11-13-2006, 06:22 PM
