586,009 active members*
4,852 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Purchasing the right linear rails for a home made cnc router table
Page 1 of 4 123
Results 1 to 20 of 63
    Mar 2017
    164
    Guys , I was debating to build a Joe's CNC , and while Joes V bearing Evolution is all that I would probably ever require, the more I study , I'm certain I could build a cnc table myself using square block linear rails , and CNCRP pro series rack and pinion .
    Sorry if my terminology isn't great yet .
    My design was to have a cutting area of 4' x 5' , as a 4/8 will not fit well in my garage . I'm interested in 3D carvings and signs , and fairly good repeatability. Will be using Nema34 for steppers , aluminum extrusion most likely from Vancouver , as I'm located in eastern BC Canada .
    Was hoping to get get opinions on these linear guides and blocks in this link below .
    https://motionconstrained.com/store/...linear-guides/
    I'm not sure if this is there lower model ? I have heard where 25mm are overkill and 20mm are fine , but I would prefer to go with these , as the cost difference isn't a lot.
    Also heard mention that you should exceed your cutting area by approx a foot on each axis for the linear guide length in order to compensate for the area lost to the blocks .
    Thanks in advance all , as I've gotta start somewhere
    Re: Purchasing the right linear rails for a home made cnc router table
    If you look at the technical info on that page, it explains what the different letters mean.
    At the end of the number, ZA means medium preload, which is good.
    C means standard precision, which relates to the height of the block. How much they can vary between blocks.
    Ideally, you want double seals, or double seals + scrapers. My guess is that these don't have double seals. But you may be able to buy double seal kits and add them yourself, but that can add $20 or more per block.
    While the price difference between 20mm and 25mm is small, you really don't gain anything, so your just wasting money. A single 20mm block can carry 4000 lbs. A 25mm block can carry almost 6000 lbs.
    Mar 2017
    164
    Thanks Gerry , I had no idea about the seals either
    falacncrouter Guest
    Hi! It is good to build your cnc router by yourself. If you are finding linear lead rails for wood cnc router of which size is smaller than 4ft*8ft, it would be better to adopt 20mm leadrail and blocks because it is enough and would save your money. To be frank, i am a staff from FALA CNC, which is a Chinese CNC router manufacturer.
    Apr 2009
    5516
    Well, if your cutting area is 4' x 5', you have to consider the largest tool diameter you're going to use, plus over-travel for limit and home switches (though with Mach3 and others you can use limit switches as home switches.) You may have to "lead in" to the edge of a workpiece and that adds additional travel. Add to this, the width of the extremities of your bearing blocks. If the spindle center is outside the footprint of the bearing blocks, that too will require more travel. The seals will add to the block footprint. Every inch wasted is money...
    Mar 2017
    164
    Quote Originally Posted by louieatienza View Post
    Wow , some great points
    +1 What Louie said. I meant to add that about the length.
    You really need to have a complete design to know exactly what you need.
    Or, you need to design around a certain length rail, and the travel you end up with is what it is.
    I like to have be able to reach at least 2" all around the spoilboard.
    About 1/8", maybe.
    Mar 2017
    164
    I see where you definetly need a design . As you guys mentioned, I have to figure out is total distance on the outside of the blocks on each axis , plus where does the spindle sit in relationship to it all .
    I noticed the rail wasn't a huge price increase adding a little extra length , but extrusion will be .
    My main concern was getting the spindles centre of gravity right , meaning ideally having it in the middle of the bearing blocks on the Y axis.
    I wanted to take the easy way out and mount the horizon beam for the X axis to the front of the vertical extrusion thats mounted to the Y axis plates . This will put the spindle forward though .
    I see cncrp pro pro version has fabricated a plate of some sorts to secure the main gantries beam directly on top of the vertical extrusion. I guess I could use guzzets
    Mar 2017
    164
    (though with Mach3 and others you can use limit switches as home switches.) ..
    Not that it changes anything design wise , but as per ger21 , I was going to use UCCNC
    my main concern was getting the spindles centre of gravity right , meaning ideally having it in the middle of the bearing blocks on the Y axis.
    It's really not that critical, especially when using linear rails. Generally, the gantry beam sits over one of the blocks, which puts the spindle somewhere between the two blocks.
    If you look at a side view of my gantry, the spindles will sit slightly in front of the blocks.
    http://www.cnczone.com/forums/cnc-wo...ml#post1181528
    Mar 2017
    164
    Quote Originally Posted by falacncrouter View Post
    I'm not a rich man , but I'm just not seeing a big price difference when jumping from 20mm to 25mm ? To me , over designing is better than under designing ?
    It's your money.
    My point is that if the machine frame was strong enough, you could literally hang a car off of the 20mm rails, and be well under their load limit. your machine will be operating at about 5% of the rated load limits of 20mm rails. If you want to spend a little more, feel free. But there will be zero noticeable difference.
    There wouldn't be any difference between 15mm and 25mm rails, on a DIY machine.
    Mar 2017
    164
    It's your money.
    I read a post one time of someone having issues with the hardware for the holes in the rails , as there were certain sizes , and one worked better than the other with extrusion. But I think the holes are the same diameter , so I'd have to check that out . If everyone is against using 25mm guide rail , I'll certainly consider going with 20mm .
    Guys , is there a recommended carriage you can buy for the Z axis that fits a 100mm spindle that is ready to be bolted up to the X axis plate? I don't really want to build that and would prefer to buy a complete one .
    Apr 2004
    733
    I used some 15mm THK and more than adequate load handling ability on my extrusion router. However my next gantry router is using 20mm and 25mm rails because the 5&6 mm tapped holes are easier to do than the 4mm ones used on the 15mm rails. I broke a couple of taps before.....
    I found the NSK 25mm (1200mm long) rails on eBay for cheap. Would rather of used 20mm since the carriages are much shorter. I would lose less travel.
    Velox sells a complete Z axis that the Joe's guys use.
    Yeah, the 15mm ones are tricky because of the small screws, but 20mm and up are fine.
    I'm not against using 25mm, they're just unnecessary.
    Mar 2017
    164
    Yes to my suprize I recently heard cncrouterparts uses 20mm rails . Good to know about the screws , as I wasn't sure which ones were causing some people grief .
    Never thought about the blocks being shorter for the 20mm rail also , will have to check that, although I don't think it will be to much of an issue.
    Regarding Z axis , thanks for the heads up . Will check them out
    Mar 2017
    164
    I'm assuming a guy wants the four bearing setup , as in theory it would have be more stable flex wise .Not understanding which screw pitch is preferred though ?
    I'm shooting for 8" of travel
    Apr 2004
    733
    I think one one reason why cncrouterparts choose to use 20mm rails is that they are just wide enough to sit flat in the narrow extrusion slot that they use.
    I had to make a larger flat aluminum mounting plate for my 15mm rails so they can be attached to the extrusion. Using 20mm rails would of avoided all that extra work.
    Mar 2017
    164
    Quote Originally Posted by jfong View Post
    That's good to know , and something that would have been totally unexpected till I got to that point. Thanks again for all your info guys
    Apr 2004
    733
    Here's a good video of a cncrouterparts machine being put together. Lots of interesting design choices.
    https://youtu.be/dY8v0j6uEJc
Page 1 of 4 123
  1. Positive experience purchasing linear rails and drivescrews
    By aarggh in forum Linear and Rotary Motion
    Last Post: 05-19-2015, 08:30 PM
  2. Drilling home-made linear rails
    By 3Dsigns in forum MetalWork Discussion
    Last Post: 10-23-2013, 12:21 AM
  3. Home made table, with linear rails & ball screws
    By nateman_doo in forum Benchtop Machines
    Last Post: 05-09-2011, 04:37 AM
  4. Home made linear bearings,
    By nobikes in forum Linear and Rotary Motion
    Last Post: 03-07-2009, 04:29 PM
  5. My first home made router table
    By mldpsu in forum DIY CNC Router Table Machines
    Last Post: 08-04-2008, 07:27 PM
