585,971 active members*
4,162 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > G.Weike Laser > Brand new G. Weike LC1390N 150 watt C02 Laser will not power on.
Results 1 to 7 of 7
    May 2017
    I just bought a G. Weike LC1390N 150 watt laser configured to run on 220 volts. Everything arrived in good condition. After getting everything set up and ready. I started up the machine. Everything looked normal. Lights came on, the head moved and all looked well. I pushed the green button for the blower and 3 seconds later, the machine went dead. I can only assume that I had the chiller, air assist and exhaust fan in the wrong plugs on the back. When I pressed the green button I could hear the exhaust fan start to wind up and that is when everything stopped. So I need to find out what failed and I need to find out the correct plugs in which to plug in the accessories.(They are not labeled). Can anyone help please?
    May 2017
    4
    Re: Brand new G. Weike LC1390N 150 watt C02 Laser will not power on.
    JayR
    I am in a similar situation.
    I would suggest to plug all the externals into a separate power supply strip by themselves.
    I just got a LC1390N 80 watt and have no power at all, water chiller, and laser look great-
    but the second I turn it on- the switch in the back ( the gcfi or circuit within the machine) immediately shuts it down.
    So interested what you come up with. My power supply is fine- so unsure what is going on.
    s
    Jun 2014
    611
    What answer do you get from their tech person? don't plug the water chiller on the back of laser machine.
    Do they have a video tech you how to set up the laser? just like this.
    How to setup your nova laser cutter - Thunder Laser
    Feb 2012
    387
    Quote Originally Posted by sonjapete View Post
    JayR
    s
    already fixed ,
    check the fuse , the exhaust fan not connect machine directly ,find seperate plug
    Lucy Lee G.WEIKE LASER
    [email protected]
    May 2017
    4
    Quote Originally Posted by Nolan Yang View Post
    Hello Nolan, yes there were videos to follow. nothing is plugged into the back they are on separate powerstrip and power.
    My problem is that the gcfi flips the whole machine off right when first plugging in.
    My problem is not a fuse-
    I am worried there is an electrical short somewhere causing this - I looked through all the wiring and they look well connected - maybe something is connected incorrectly?
    My machine has yet to power on- since unpacking.
    All is installed- externals on separate powerstrip and power. the ground is installed.
    I have no idea what to do next with this new machine.
    open to ideas?
    thanks
    Sonja
    May 2017
    4
    Hello Lucy-
    I have emailed your company numerous times and sent my questions directly on your website and had no reply. I just purchased my machine and it has not powered up yet-
    I would like some technical support.
    It is not a fuse and there are no externals plugged into the machine- they are all on another power source,
    the GCFI switch in the back immediately shuts down the machine when plugged in- yet the power strip it is on stays on.
    Aug 2010
    4
    I am having a similar problem. I have a 100 watt lc1390n and it just trips my gfci when I try to turn it on. It’s grounded to the earth outside also.
  1. G. Weike laser won't engrave at full power
    By jimbo-tron in forum G.Weike Laser
    Last Post: 08-23-2016, 06:48 AM
  2. No power to 50 watt chinese laser.
    By jeff4freedom in forum Laser Hardware
    Last Post: 02-18-2015, 04:04 PM
  3. Minium Power from a 100 and 150 watt laser
    By MonoNeuron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-01-2011, 03:43 PM
