And that is how I did it also. I started with curved end wire, offset it, and then went and offset for each fret. I then did a skin.
I have V28. What is 3D wire frame?
I can get it to machine but it won't follow the curve. It simply cuts straight across. Your program is cutting the curve bottom
Then in all my frustration trying to find solution, I ran into this situation where I tried to create a pocket, with wire frame and then extrude that curved wire frame.and it wont extrude less then 3.4mm
You saying that file I attached works for everyone but me.
Last night I got a new component and BC crashes anytime I try to do anything with the image.
Rob
