585,930 active members*
3,797 visitors online*
    Vertical tube OK?
    To save floor space I am thinking about building a 100W CO2 laser with the tube mounted vertically.
    I have the ceiling clearance and I realize I might have to use a step ladder for optics adjustments.
    Are there any other problems or considerations to think about?
    Bertho
    Nov 2008
    644
    Re: Vertical tube OK?
    I can think of three areas. Check with the tube supplier if it's ok, Make sure you get good water flow a meter or so up and the biggest issue might be beam stability. Horizontal is pretty stable but you might see machine movement causing the tube to move which will throw off your alignment.
    Quote Originally Posted by Dean448 View Post
    Thanks for replying.
    I have since learned that a vertical tube is not a good idea since any air bubbles would be right at the end mirror.
    Bertho
    Nov 2008
    644
    Not sure what that means. The mirror is in CO2 and I haven't had bubbles since going with a chiller that draws water from a tank. Maybe I also don't have bubbles since going to 100% RV antifreeze. But I'll believe it if you got that from a manufacturer. Don't trust everything you read on this forum
  1. Vertical/Semi-vertical tables...anyone? My thoughts...
    By millerized in forum DIY CNC Router Table Machines
    Last Post: 05-01-2017, 11:29 PM
  2. Steel pipes cutting round tube and squre tube , fiber cutitng is best ?
    By laserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-23-2017, 10:42 AM
  3. laser tube in vertical position
    By gianluca70 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2015, 12:23 PM
  4. stock Vertical Turning Center, CNC Vertical Lathes, SMTCL VTC6070
    By SMTCL Europe in forum News Announcements
    Last Post: 05-09-2011, 12:57 PM
  5. Vertical Storage of Metal Tube and Bar
    By Blu_Rock in forum MetalWork Discussion
    Last Post: 12-20-2008, 09:06 PM
