585,978 active members*
4,189 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Jul 2016
    25
    How to hold 1/2" hex shaft
    I have the Tormach PCNC 770 mill and this tooling setup. I need to hold a 1/2" hex shaft (which I don't have yet) in the spindle. How could I do this. If I understand correctly, 1/2" hex is actually a bit bigger than 1/2" on the diagonal. Would the shaft fit in a 1/2" spindle?
    Feb 2006
    7063
    Re: How to hold 1/2" hex shaft
    Get a 1/2" Hex R8 collet.
    Regards,
    Ray L.
    Jul 2016
    25
    Quote Originally Posted by SCzEngrgGroup View Post
    I have not been able to find one of these. Do you have a source?
    Dec 2013
    5717
    A 1/2 inch hex is 0.5774 across the points.
    That is a very uncommon collet, but I actually found them. https://www.aliexpress.com/item/Hot-...8.4.104.mvAXAj
    Depending on what you are doing, a drill chuck may work also, but they don't like to be side loaded much.
    Feb 2009
    152
    Quote Originally Posted by icecats View Post
    This is probably your best option- will hold a lot of hex and round parts.
    Z LIVE CENTER 3" 3 Jaw Precision Lathe Chuck with R8 Shank (Non-Rotating) | eBay
    Jul 2016
    25
    I found this 5C Hex Collet on Tormach's website. How could I use this with my current setup?
    Dec 2013
    5717
    Unless they make a 5C collet holder that will mate to your spindle, I don't see how a 5C collet would work. A 5C collet is about 1.25 on the OD. We are assuming here that your spindle is a R8, that is the case, correct?
    Jun 2014
    1780
    Hardinge makes an R8 hex in decimal sizes, kind of pricey though, and an 18 day wait as they are out of stock.
    https://www.shophardinge.com/product...17570028000000
    mike sr
    Jul 2016
    25
    I am leaning towards purchasing a 5/8" or 3/4" inch chuck with a jacob's taper. The hex should fit in here.
    Sep 2009
    624
    Hex stock half inch across flats is around 0.56 point to point.
    Two options: turn it round for a half inch or so and hold with your ER collets. That does assume you've got a lathe.
    Or buy some tooling. A small 3-jaw chuck with an R8 backplate may be your best option. R8 hex collets aren't obviously available, and -depending on what you're doing- holding either tooling OR a workpiece in a bigger drill chuck could be exciting if the drill chuck is mounted on a taper arbor (that is, held by friction only) - drill chucks are a really bad way to hold milling cutters because the side forces can work the whole assembly loose during a cut.
    Or, wild idea, make a 5C collet holder for your spindle TTS spindle. 5C is readily available with hex, round, square shapes, and not outrageously expensive. Remember, you don't have to tighten the collet from the rear: a compression nut over the front will work as well and would easily pass the half hex stock. Problem with an approach like this is that it's at least a 2 1/2-3 inches long and could be a bit wobbly depending on design. But with a little work, you could probably make it all with just the Tormach; don't necessarily need a lathe. That might actually be a rather slick piece of kit to have for those oddball situations where the more conventional holders just don't work due to shape or diameter.
    Jun 2012
    311
    Depending on the concentricity required, you could take a 1/2" TTS set screw holder and mill a 1/2" hex into it. Make sure one set of flats are perpendicular to the set screw hole.
    Mar 2009
    1863
    Why don't you machine a hex into some aluminum soft jaws. If you need help making the program, send me a sketch of what you're trying to do and I'll do it for ya. It's really easy to machine a hexagonal pocket in aluminum jaws.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jun 2012
    311
    Quote Originally Posted by Steve Seebold View Post
    How would that allow him to hold the hex in the spindle?
    Jul 2016
    25
    Do you mean soft jaws that fit with some form of Tormach tooling?
    Dec 2013
    5717
    You could make a split adapter to fit your R-8 collet.
    What is your end goal here, is it to ''turn'' the hex as in a lathe?
    Jul 2016
    25
    Yes, that is what I would like to do. What do you mean by split adapter?
    Dec 2013
    5717
    You make a round plug that fits your collet, put a hex hole in it, then saw it in half so it will squeeze onto the hex then the collet is tightened.
    Feb 2006
    7063
    Quote Originally Posted by IMT View Post
    That's easy! Just weld an R8 shank to the vise!
    Regards,
    Ray L.
    Dec 2013
    5717
    Regards,
    Ray L.
    :cheers:
    Jul 2016
    25
    Can this be done without a lathe?
Page 1 of 2 12
  1. 1/4" and 1/2" Delrin hold down tips needed for Stinger1
    By originator in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-19-2014, 10:06 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. Can i use the emergency stop like a "slide hold" button?
    By Vegabond in forum Mach Wizards, Macros, & Addons
    Last Post: 07-11-2011, 11:13 PM
  4. Can V9 leave "tabs" to hold parts?
    By juxtoposed in forum Mastercam
    Last Post: 03-26-2010, 08:48 PM
  5. Mitsui Seiki VR5A orientation "Feed Hold" 6M
    By woonsteel in forum Fanuc
    Last Post: 05-01-2009, 02:39 PM
