584,857 active members*
4,515 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > WHAT MILL OPERATION FOR THIS FEATURE
Results 1 to 7 of 7
    Sep 2010
    86
    Im new into 4 axis milling. Would you please tell me how to go about machining the "red profile" as well as the fillet on the edges.Thank you in advance.
    Dec 2008
    441
    Re: WHAT MILL OPERATION FOR THIS FEATURE
    Havent tried it on a 4 axis like that, but you can try the swarf
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Jun 2010
    4252
    Me, I would probably stick the rod into a centred ER32 collet on the mill table and do a simple milling.
    I would use a snug fit pin throught the holes for rotary alignment.
    Cheers
    Roger
    Dec 2013
    5717
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    You have 100mm ER32 collets?
    Jun 2010
    4252
    Oh yeah, along with a bridge to sell.
    There were no dimensions on the jpg as far as I could see.
    Hum - IF 100 mm diameter, then two solid angle brackets at right angles and some solid clamps.
    I reckon I sometimes spend more time figuring out the jigging than doing the machining. It happens that way.
    Cheers
    Roger
    Dec 2013
    5717
    Cheers
    Roger
    Yeah, you have to look at the PDF also.
    I hear what you're saying, jigging is half (or more) of the job.
    Jun 2010
    4252
    PDF?
    That came up black on my screen. Oh well.
    Cheers
    Roger
  1. Dynapath face mill feature
    By mattmont in forum Dynapath
    Last Post: 01-23-2015, 02:01 PM
  2. Replies: 3
    Last Post: 02-12-2013, 05:37 PM
  3. V25 Mill Radius Edge Break On Angled Feature
    By JoeCraftsman in forum BobCad-Cam
    Last Post: 02-09-2013, 09:36 PM
  4. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  5. Mill a 5 axis feature / plane orientation
    By mishikwest in forum Mastercam
    Last Post: 06-01-2010, 07:43 AM
