586,009 active members*
4,775 visitors online*
Results 1 to 7 of 7
    Jan 2010
    6
    Limit Switch Software Problem
    I recently rewired my limit switches to free up a pin for an emergency stop button and auto zeroing and now each time I engage a limit switch it doesn't allow me to reset the switch automatically and I have to go back into Config - Ports and Pins in Mach 3 to disable them each time before I can reset my cnc machine. I was previously able to do so via a warning screen that showed me that a limit switch was triggered and asked me if I wanted to reset the switch automatically. I'm not sure why this is happening now and don't want to waste a lot of time trying to figure this out myself. Is there anyone that has had a similar problem or that can give me a hand with solving this problem for me. Thanks in advance for any assistance that you can provide.
    Re: Limit Switch Software Problem
    Do you have Automatic Limit Override turned on?
    Or have you tried Manual override?
    Jan 2010
    6
    I have corrected the problem myself and I did have it set on manual limit override. Thanks for your reply.
    Aug 2017
    12
    Hi everyone am a newbie and in need of help
    On how to wire up limit switches to my new
    Cnc 6040z USB 3 axis machine ?
    The board in the black box is JP-3163B with
    Optional A-axis connectors or (4th axis) now there's
    Connectors on it which I don't know where or
    how to connect 2(limit switches) on each axis???? Please help
    Mar 2007
    2083
    is this your board ???
    Attachment 370550
    (first web search result for JP-3163B)
    john
    Aug 2017
    12
    The board you showed me is similar, im send
    pic attachments of actual board and also a single
    Stepper motor card for the A axis I bought that I
    Want to connect ..also mine has only one big parallel
    DB connector and no db 9...
    Mar 2007
    2083
    combining the information I found on the web with your second photo
    I would connect the limit switches like this for the first 3 axis
Name:	photo 2 plus limit switch detail.jpg
    when you add the 4th axis
    you could either use the input labled probe if your not using a probe
Name:	4 axis limits.jpg
    or
    combine the 4th axis switches with one of the other axis limit switches
Name:	probe & 4 axis limit switch detail.jpg
    I can not add more detail to this diagram to connect the 4th axis driver
    without detailed photos of the connectors
    or the user manuals for the 3 axis board and the single axis driver
    Attachment 370614
Name:	connecting 4th axis 2 .jpg
    John
  1. A different Limit Switch Problem
    By bamabones3 in forum Chinese Machines
    Last Post: 02-23-2012, 08:00 PM
  2. Software Limit Switch
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 02-14-2012, 06:36 PM
  3. Limit switch problem?
    By Bill Gillen in forum Centroid CNC Control Products
    Last Post: 05-08-2008, 06:02 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
