585,942 active members*
3,204 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > ACME Leadscrew with Aluminum Nut Block
Results 1 to 9 of 9
    Hello All !
    If anyone is interested in a DIY CNC table, I have a pair of Brand New IGUS ACME Leadscrews WITH the matching Aluminum Nut Block for sale on Ebay.
    The item number is 371533320471 and the link is NEW ACME Leadscrew AND Nut Linear Motion CNC Robotics Worm Drive Lead Screw Ball | eBay
    They are perfect for driving the Gantry of a 4'x8' CNC table!
    They are brand new, I never used them for my project.
    Check em out! Thanks for looking!
    Re: ACME Leadscrew with Aluminum Nut Block
    Seems our client has similar product.
    May 2011
    790
    Quote Originally Posted by DSTechLabs View Post
    A 4mm per rev lead or ball screw to drive 8' of movement is probably the worst design decision you could possibly make for a CNC machine.
    Jun 2010
    4256
    What an odd comment.
    Why?
    Cheers
    Roger
    May 2011
    790
    Quote Originally Posted by RCaffin View Post
    Why?
    Cheers
    Roger
    It will be very slow. If you use the Nook crit speed calculator (which is probably over conservative but gives a good idea)
    Metric Critical Speed Calculator | Nook Industries
    It says the OD is 18mm in the add, not sure what the exact root diameter is, but if we use 16.5mm as the root diameter, and 2385mm as the length as per the advert, and an end fixity of B, we get a max speed of 351 RPM.
    351 x 4 = 1404mm/min
    1404/25.4 = 55 IPM max speed
    93.9 inches / 55 IPM = 1.7 minutes just to jog the table from back to front.
    The nook calculator may be conservative and the actual bearing to bearing distance may be a bit less, but that's the ballpark you're looking at.
    Perhaps I shouldn't have posted. I just didn't like the though of some poor guy saving all his lunch money to spend $395 USD per screw because the add said it's perfect for an eight foot travel CNC machine. He'd be screwed so to speak. Get it? Little play on words there.
    Dec 2013
    5717
    Nic 77 is correct. That small lead would not be appropriate for a lead screw on a larger router. That might make a good pull screw for a tension test fixture.
    For a 8 foot table/gantry I would say 25 mm or more lead would be correct. The screw on my 8 foot table has a 40mm lead.
    Jun 2010
    4256
    Oh, to be sure, over 8' it would be slow. But maybe the application does not mind?
    worst design decision you could possibly make seems a bit overboard though.
    Cheers
    Roger
    May 2011
    790
    Jim, great minds think alike. :cheers:
    Roger, you are correct. You could make it out of paper mache. That would be a worse decision. I withdraw "the worst design decision" from my previous statement and replace it with "a really really bad design decision" in accordance with your objections .
    Jun 2004
    6618
    Well...someone thought is was a good idea for something. Somebody manufactured it.
    Lee
  1. ACME Leadscrew question
    By whmeade10 in forum Open Source CNC Machine Designs
    Last Post: 11-28-2007, 01:27 PM
  2. acme leadscrew
    By drfoz in forum Commercial CNC Wood Routers
    Last Post: 08-05-2007, 05:57 AM
  3. how to straighten an acme leadscrew ?
    By belgrado in forum MetalWork Discussion
    Last Post: 09-14-2006, 05:36 PM
  4. Leadscrew or Acme for Al. Router
    By js530 in forum DIY CNC Router Table Machines
    Last Post: 05-12-2005, 01:23 AM
  5. Acme leadscrew or Trapezoid leadscrew is better?
    By minicnc in forum DIY CNC Router Table Machines
    Last Post: 03-07-2005, 06:57 PM
