585,575 active members*
3,975 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > AMADA PEGA 357 communication problem DNC5 with CNC Fanuc 04 PC
Results 1 to 18 of 18
    Oct 2016
    8
    Hello everyone,
    I have problem to transfer file form my PC(DNC5) to machine(Amada Fanuc 04PC). Check cable everything looks fine. I think my machine loose parametars data , but I do not have my original parametars and do not know how to insert new one and which one is for communication between CNC and PC , if someone have same machine please just take picture of this parametars or write it down ... Or if you have any suggesstion I am willing to try.
    I also try to change COM 1 , COM 2 port, change configuration in DNC , but nothing .....
    Machine : AMADA PEGA 237 FANUC 04 PC year: 1994
    BR !
    Mar 2009
    101
    Re: AMADA PEGA 357 communication problem DNC5 with CNC Fanuc 04 PC
    What baud rate and stop bits are you running on PC side?
    Oct 2016
    8
    baud rate : 1200
    parity : even
    data bits: 7
    stop bits: 1
    Is there option to check this parametars on machine ?
    Mar 2009
    101
    Quote Originally Posted by Mrava View Post
    baud rate : 1200
    parity : even
    data bits: 7
    stop bits: 1
    On set up page select SIO 3 That will change param 340 & 341 to 3.
    That tells control to look at param 312 for communication.
    Set 312 to match your baud and stop bits
    set 312 00000111 this is 1 stop bit, 1200 baud
    Of course you need proper config cable.
    Not sure length of your cable, I typically run 9600 baud. which woule be 00001010
    Oct 2016
    8
    Quote Originally Posted by AMADAJOE View Post
    When I set to SIO3 , it change 340 to 3 but 341 still stay 1. Then I change 341 manually to 3 and set up parametar 312 to 00000111, but when try to prepare machine to READ , it automaticly display error HAND SHAKE ERROR ! , so this wont work.....
    Mar 2009
    101
    You have to change both input device & output device on set up page = SIO 3
    Yes you can also go to 340 & 341 and set them to 3
    340 is for input to Control
    341 is for output from Control
    1. Do you have proper config cable?
    2. Was DNC working prior?
    3. What led up to DNC not working? New Pc? New Install? Thunder storm? etc
    Oct 2016
    8
    I think it was voltage drop ...
    Mar 2009
    101
    Voltage drop in shop? did you loose all parameters? Usually CRT/MDI board goes bad. Plugs into master board. Maybe part # A02B-0086-C052
    Apr 2005
    629
    Regarding "lost parameters" on a Fanuc control, there are three ways I know they "go away":
    1) Operator started playing where he/she shouldn't have been.
    2) Fanuc service guy had to repair something, sometimes parameters get deleted depending on what service was performed.
    3) Batteries are dead and someone shut off the machine OR changed batteries while power was off on the machine.
    Too late now, however, be mindful that parameters are often like the "Magic smoke" in electrical devices, once you let them out, you can't fetch them and stuff them back in from thin air - Make backups.
    Chris D
    Mar 2009
    101
    Quote Originally Posted by Chris D View Post
    Chris D
    4. Loosing power or turning off while edit flashing.
    Apr 2005
    629
    Ahh, that is one I have never run across, however, I could see that being a problem as well.
    Chris D
    Oct 2016
    8
    No I have not loost any parameters, still there. Also I asked FANCU servicers to send me my paraametars , because he take picture last time he was in my company , and parametars are ok ....
    Oct 2012
    40
    still you are use pc for RS232c communication, here i have one device for transfer your program to machine with USB pen drive option.
    The device is very compact and user friendly. with my device you can transfer program and parameters to machine and also take backup of the same in to device.
    it has 4Gb internal memory to store program and parameters, 2.5" Lcd display to see the program or parameter data, 2 usb port to transfer or received data.
    Please feel free to contact me for further details of device.
    you can mail me>>>> [email protected]
    website>>>>> protecdncsystems.com
    call or whatsapp >>>> +91 8149636586
    Apr 2009
    1379
    That shouldn't lose the parameters; only programs.
    Oct 2012
    40
    Quote Originally Posted by memoryman View Post
    Yes I know that, but in power fluctuations crt mdi bord are get damaged with RS232 connection To eliminate that I made this device. It's very compact and user-friendly.
    Please share your email address, I will send you user manual of device for the further details and features.
    [email protected]
    Apr 2009
    1379
    I was referring to AMADAJOE's post: "4. Loosing power or turning off while edit flashing."
    Mar 2009
    101
    On a 04PC, I have experienced it many times. I would guess your next logical question would be what kind of experience I have. I worked for Amada 14yrs, and another 15 doing the same deal under a different umbrella. While you say it shouldnt, thats fine but I can tell you it does happen.
    Apr 2009
    1379
    AMADAJOE, in my experience, interrupting a EDITING operation 'should' only cause a 101 alarm; the actual reality may be different.
    I was not going to question your experience.
  1. amada pega 344 fanuc w 6m control
    By stacebg in forum Fanuc
    Last Post: 03-19-2017, 10:53 PM
  2. AMADA PEGA 357 (black screen problem)
    By Mrava in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2017, 09:10 PM
  3. amada pega 345 fanuc o4-pc
    By telrefaie in forum Fanuc
    Last Post: 06-29-2016, 08:52 PM
  4. amada pega 357 - fanuc 6m
    By stevematt in forum Omni CNC
    Last Post: 04-01-2016, 05:59 AM
