585,705 active members*
3,836 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > No load rpms on servos without specs
    Dec 2008
    28
    I am converting an old Tree mill to use new hardware and am to the point where everything is wired (in place not plugged in), I have control of the spindle rpm and am now wanting to add control of X, Y and Z encoders/servos. There is almost no documentation that I can find on my encoders and servos so I am looking for help so I can setup my Gecko G320X drives. On the servos I have a part number of M113-A10K-900, I believe they are Gould MFG and one has been rebuilt before I owned the machine. One the encoders they are Sumtak MFG and have 9304-1293 500p/r and LBL-008-500. There is a wiring diagram on them and I am sure they are wired accordingly and I am also confident the servos are wired correctly as well. I am trying to figure out what the no load rpm for these servos are so I can go through the Gecko testing so it is done correctly. All help is greatly appreciated.
    24220
    Re: No load rpms on servos without specs
    Sumtak was taken over by Renco I believe and they were in turn taken over by Heidenhain.
    For DC servo's you can usually reckon on 2krpm, max, and BLDC anywhere up to 6krpm.
    If you have the max voltage rating for them, you could back feed them with a motor of some kind and measure the generated voltage at recorded the RPM, this will give you the maximum rpm if you extrapolate the numbers.
    Al.
    Albert E.
  1. Large load on the neutral with 220v 1-phase servos, good or not?
    By jeeybee in forum CNC Machine Related Electronics
    Last Post: 08-26-2016, 06:49 AM
  2. Any way to get more torque out of the 770 spindle motor at low RPMs?
    By mrquacker in forum Tormach Personal CNC Mill
    Last Post: 04-11-2016, 07:06 PM
  3. Keling Size34 motor axial load specs?
    By RomanLini in forum Automation Technology Products
    Last Post: 09-05-2011, 01:47 PM
  4. Screen goes out at 6000 rpms
    By dlenardu in forum Milltronics
    Last Post: 03-30-2011, 01:51 AM
  5. Ametek Servos - need specs
    By dowling177 in forum Servo Motors / Drives
    Last Post: 02-20-2005, 04:55 PM
