585,880 active members*
8,559 visitors online*
    Jan 2015
    138
    Engraving lines from image
    I have a drawing in Sketchup which consists of a fairly simple set of straight lines. I can export it as a bmp (free version).
    When I import it into F-engrave, set for engraving, the single lines turn into double lines, very closely spaced. It is clear what is happening, F-engrave is tracing both sides of the line.
    This made me think I needed the drawing in a vector format. I downloaded Inkscape, imported the drawing and used Path -> trace bitmap -> edge detection. This gave me a vector image, I deleted the bmp.
    Next I did Save As and picked the only dxf choice, Desktop Cutting Plotter (Autocad ..something..). F-engrave will only read bmp or dxf.
    I get a choice of using either ROBO-Master type of spline or LWPOLYLINE type of line. The second one F-engrave reports as "no image loaded", the first one loads, but the splines have made my corners *very* rounded and my straight lines curves.
    Any other ideas, or how to fix what I've got?
    Steve
    Jan 2015
    138
    Re: Engraving lines from image
    I set up LibreCAD and drew the basic figure. This imports (as a dxf) into F-engrave with no problems.
    Nov 2020
    You are not the first one with such a problem. Yeah, unfortunately, the soft is pretty bad optimized. Sometimes, it is tough to perform different actions that look really easy in the beginning. Still, the internet is full of various video tutorials where you can find out how to do it. Just take a look at some https://depositphotos.com/stock-vectors.html videos you might find on the internet. Try drawing the primary figure and import it. I am not sure about that, but it might work. You will find out if it works by yourself.
  1. Image Engraving Software
    By citrusguy in forum Uncategorised CAM Discussion
    Last Post: 06-28-2017, 03:04 AM
  2. problem "lag" on k40 speed slows down on some lines engraving halftones image
    By hargossath in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-22-2016, 07:20 AM
  3. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  4. realistic image engraving
    By emilcnc in forum Uncategorised CAM Discussion
    Last Post: 03-21-2007, 06:22 AM
