585,894 active members*
5,270 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > VCarve Pro vs Aspire
    Dec 2014
    61
    I have been using VCarve Pro for about 4 years now with my CNC (3) axis router. Now I just purchased a laser engraver and cutting machine. If I want to do 4th axis or rotary work would I be better to go to Aspire? I would also envision doing 3D work with a 4th axis.
    Thanks.
    Re: VCarve Pro vs Aspire
    V Carve Pro has the same rotary capabilities (wrapping) as Aspire.
    And the current version of V Carve Pro has 3D machining capabilities.
    What Aspire adds is 3D relief modeling capabilities. If you need those, than you probably want to get Aspire. If you don't plan on doing your own modeling, then V Carve Pro can do just about everything else that Aspire can do.
    Dec 2014
    61
    Thanks so much for the advice. I guess I never realized VCarve had the rotary capabilities.
  1. vcarve and aspire
    By msdeltaguy in forum Vectric
    Last Post: 12-01-2011, 05:00 PM
  2. Aspire 2.5 & VCarve Pro 5.5 Released
    By Tony Mac in forum Vectric
    Last Post: 12-12-2010, 12:11 PM
  3. Replies: 10
    Last Post: 05-02-2010, 02:21 AM
  4. Aspire 2 and VCarve Pro 5 Released!
    Last Post: 04-10-2010, 11:32 PM
  5. aspire, vcarve pro
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 03-16-2009, 10:56 PM
