585,987 active members*
4,436 visitors online*
    Dec 2005
    504
    Dynatorch post for Fusion 360?
    Does anyone have a Dynatorch post for Fusion 360?
    I'm sure I can modify a post to use G23/G25 myself but I figured I'd ask before I re-invented the wheel.
    Dec 2005
    504
    Re: Dynatorch post for Fusion 360?
    I modified the WinCNC Plasma post processor for my Dynatorch. It was fairly easy. Now I need to work on my tool library so I can get the correct feeds, speeds, and kerf width. Over all the code produced looks very clean.
    Not sure if the Dynatorch can do cutter comp (G41/G42) so I switched the compensation type to "In computer" on the dialog tab.
    Jan 2004
    3154
    We appreciate that you shared
    www.integratedmechanical.ca
    Dec 2005
    504
    I just noticed that Autodesk now has a post processor for the dynatorch. I made the switch yesterday and it has been working as expected.
    https://cam.autodesk.com/posts/downl...torch%20plasma
    Just FYI, DT does support G41/G42.
  1. Dynatorch XLS - Sheetcam Post Processing file
    By chemosavi in forum DynaTorch
    Last Post: 11-12-2016, 11:47 PM
  2. fusion 360 post?
    By mikethemachine in forum Post Processor Files
    Last Post: 05-23-2016, 06:01 PM
  3. Tormach Post and Fusion 360
    By grimms3 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2015, 04:58 AM
  4. Fusion 360 Post
    By wildwhl in forum Tormach Personal CNC Mill
    Last Post: 08-27-2015, 05:10 AM
  5. Dynatorch Post Issues?
    By super95awd in forum SheetCam
    Last Post: 02-27-2011, 09:54 AM
