585,759 active members*
4,004 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Sep 2007
    100
    Re: Underwater machining ?
    Here is a link to our drill supplier
    Applied Matrix
    Drills range in size from .075" -3" diameters
    300-500 sfpm
    .0003"-.001" feed per revolution
    I have drilled granite surface plates using these feeds and speeds
  2. #22
    Jun 2010
    4256
    Hi tc26
    Valuable info! Thank you.
    Cheers
    Roger
  3. #23
    Sep 2007
    100
    You are welcome.
    Thank you
  4. #24
    Mar 2008
    51
    Hello Roger,
    You could also try Wrisley Abrasives for diamond tooling.
    Diamond Tools - Wrisley Abrasives - Diamond Tools - Wrisley Abrasives - Home
  5. #25
    Nov 2007
    2151
    This might work in your case
    In the past I have used diamond hole saw drills to make 2" holes in 3/8 glass. Using clean water and a clay dam around the area to be drilled. fill clay dam around the tool with water keeping the tool underwater at all time. chip removal was simple flooding over the dam with clean water. when it started to look like milk I poured more water and let it flood over the clay dam .
  6. #26
    Jun 2010
    4256
    Hi emd68
    References from customers are apreciated - thanks.
    Cheers
    Roger
Page 2 of 2 12
  1. Awesome underwater aquatic scene
    By custom dxf file in forum News Announcements
    Last Post: 12-02-2009, 05:52 AM
  2. Linear Slides from PBC Linear Assembled in Underwater Drill
    By Pacific Bearing in forum News Announcements
    Last Post: 06-24-2009, 08:54 PM
  3. Cutting underwater with a plasma
    By duraflap in forum Waterjet General Topics
    Last Post: 06-09-2008, 05:19 AM
  4. Underwater Plasma ?
    By Barry_ward in forum Waterjet General Topics
    Last Post: 05-03-2007, 01:10 PM
  5. The Great Underwater ROV Project of 2005!!
    By JavaDog in forum Hobby Discussion
    Last Post: 04-24-2006, 01:04 AM
