584,862 active members*
5,508 visitors online*
    Jun 2017
    Communicating with Gerber Saber 408
    Hi Everyone,
    I've been tasked with bringing our old Gerber 408 into the modern age by converting it to accept G-Code posted from Mastercam 2017 but I've hit a snag. From my understanding, the Gerber normally functions as a plotter/printer, not a typical CNC router. I've gotten as far as posting a test program with a Gerber post supplied by our Mastercam dealer, but cannot send the program over to the Gerber. We uses CISCOEdit to send all out G-Code to our other machine, a 1999 Anderson EXXACT DUO, but I don't think it's possible to do it in the same manner for the Gerber. CISCOEdit transmits one line at a time, but I believe the file needs to be send as a whole entity for the Gerber to receive it. I'm currently connected via Serial port although I can't say with confidence if my settings are correct.
    Any guidance would be much appreciated.
    Tanner.
    Jun 2017
    Re: Communicating with Gerber Saber 408
    Just going to update this in case anybody else runs into the same problem I was having.
    CIMCOEdit will transmit to the Gerber, it was just a matter of getting the settings right.
    Stop bits: 1
    Parity: Even
    Baud: 9600
    Data bits: 8
    Here's some sample code for anyone that tries to get a post working. This code cuts a perfect circle, a rectangle with square corners, and a square with a radius. It works decently well, although it does dwell momentarily at the beginning of the circle.
    Code:
    (NEW MCAM GERBER TEST.NC)
    (TOOL -  1 |   1/2 STRAIGHT BIT             | DIA. - 0.5000)
    G20
    G00 G90
    T1 M06
    G00 G90 X3.9479 Y11.2037 S18000 M03
    Z2.75
    Z.85
    G01 Z.75 F100
    X4.0351 Y10.2075 Z0. F200
    G02 X4.037 Y10.1639 I-.4981 J-.0436
    G03 X7.287 Y6.9139 I3.25 J0.
    X10.537 Y10.1639 I0. J3.25
    X7.287 Y13.4139 I-3.25 J0.
    X4.037 Y10.1639 I0. J-3.25
    G02 X4.0351 Y10.1204 I-.5 J0.
    G01 X3.9479 Y9.1242 Z.75
    G00 Z2.
    Z2.75
    X19.6236 Y13.4759
    Z.85
    G01 Z.75 F100
    X18.6275 Y13.3887 Z0. F200
    G02 X18.5839 Y13.3868 I-.0436 J.4981
    G01 X14.5705
    G03 X14.3205 Y13.1368 I0. J-.25
    G01 Y7.3397
    G03 X14.5705 Y7.0897 I.25 J0.
    G01 X22.5973
    G03 X22.8473 Y7.3397 I0. J.25
    G01 Y13.1368
    G03 X22.5973 Y13.3868 I-.25 J0.
    G01 X18.5839
    G02 X18.5403 Y13.3887 I0. J.5
    G01 X17.5441 Y13.4759 Z.75
    G00 Z2.
    Z2.75
    X33.0287 Y14.422
    Z.85
    G01 Z.75 F100
    X32.0325 Y14.3348 Z0. F200
    G02 X31.9889 Y14.3329 I-.0436 J.4981
    G01 X29.9889
    G03 X28.7389 Y13.0829 I0. J-1.25
    G01 Y9.0829
    G03 X29.9889 Y7.8329 I1.25 J0.
    G01 X33.9889
    G03 X35.2389 Y9.0829 I0. J1.25
    G01 Y13.0829
    G03 X33.9889 Y14.3329 I-1.25 J0.
    G01 X31.9889
    G02 X31.9454 Y14.3348 I0. J.5
    G01 X30.9492 Y14.422 Z.75
    G00 Z2.75
    M05
    M30
    Hey Tanner
    What post processor are you using to get g-code?
    regards
    Marcus
  1. gerber saber 408
    By schantal in forum Gerber
    Last Post: 09-25-2018, 09:29 PM
  2. Z axis-encoder-motor problem on Gerber Saber
    By vipers95 in forum Commercial CNC Wood Routers
    Last Post: 04-09-2009, 05:49 PM
  3. Cincinnati Saber 750
    By clip in forum Cincinnati CNC
    Last Post: 12-03-2008, 05:32 AM
  4. How to cut jobs longer than the table using a gerber saber w/artpath
    By Cocoa Astros in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2008, 04:02 PM
  5. light saber
    By go-off-road in forum Mini Lathe
    Last Post: 09-08-2006, 05:43 PM
