585,956 active members*
4,617 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Hmm what should i put my mini mill on? Table? Toolbox?
Results 1 to 9 of 9
    Jul 2011
    124
    Got a maxNC 15 cnc mill that just showed up and currently it's in pieces (thanks UPS) and I've never really milled stuff before but I can already see things starting to pile up. collets, parallel bars, end mills etc. Not that I will have much because I still have no clue what I am doing but do these machines shake and vibrate a ton
    Would I be ok using a small cheap cart like this or should I get a bottom toolbox?
    Attachment 364724
    Nov 2011
    205
    Re: Hmm what should i put my mini mill on? Table? Toolbox?
    That looks wimpy. I would go with the bottom tool box.
    Don
    Jul 2011
    124
    Should i bolt it to the top or are they sturdy enough to not wobble around?
    as soon as i get these anti back lash nuts changed i can turn it on and play around
    Nov 2011
    205
    A big drip tray over plywood.
    Don
    Jul 2011
    124
    Quote Originally Posted by DonKes View Post
    Don
    I have to get a mister setup once I'm up and running. Any recommendations?
    Nov 2011
    205
    Sep 2006
    6463
    Hi....I use a regular steel bench with draws and an open space for larger items etc.....cost me A$250 about 2 years back.....the CNC mill I have came with an enclosure so it went straight onto the bench.
    You will need some form of enclosure, even a shower curtain, to keep the chips in place or you'll be eating them......oh yeah, and a wet vac too.
    Ian.
    Apr 2017
    84
    Hi Gamble.
    Whatever you put your machine on it has to be rigid. At the very least The red tool trolly needs to be braced to precent the whole thing just folding when the machine changes direction in a hurry. I've seen some pretty flimsy affairs people mount their mills on and often wonder if the last. I put mine on a steel welding table that 'seemed' to be rigid enough. When I ran the mill/router in test, I was surprised to see the table moving whenever the mill stooed or the gantry changed direction. If you can't bolt whatever you are using to the a solid wall, it will move. If its got wheels on it, they need to be the locking variety or it will move. Hope this helps.
    Feb 2008
    51
    I built a cart of 1 inch heavy wall box tubes, it's on casters but I have a set of feet that thread down and hold it off the ground, the unit is heavy, but my shop space is limited so I need to move things here and there.
    I do like being able to work outside on nice days.
  1. High Torque Mini Mill (base, column, table - no head/spindle)
    By The Geekineer in forum For Sale Only
    Last Post: 03-17-2015, 08:33 PM
  2. CNC for LMS 3677 Mini Mill Large Table
    By pws in forum Benchtop Machines
    Last Post: 08-05-2012, 02:40 PM
  3. mini mill table not flat
    By chicotwo in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2008, 03:39 PM
  4. Mini mill base/xy table question
    By akraven in forum Benchtop Machines
    Last Post: 11-13-2006, 08:25 PM
  5. Pictures of my flood coolant table for my CNC mini-mill
    By InspirationTool in forum Benchtop Machines
    Last Post: 10-11-2006, 06:06 PM
