585,942 active members*
3,388 visitors online*
    Jun 2017
    V-bit rough fiinish in softwood
    Hi there,
    I 'm facing a lot of tear off in soft wood (spuce) using V bits and ball nose. I was wondering if someone could advice me on what might be my mistake here. I've been using bits of other shape than "V" and ballnose with great results and I can't figure why I'm struggling with these. I tried many different spindle speed and feed rate setups with no good result.
    Thank you for you help!
    -Djoe
    May 2006
    803
    Re: V-bit rough fiinish in softwood
    Realize the tip of a ball-nose cutter has a zero velocity and no rake.
    Jun 2017
    thank you bostosh for the answer but as you can see on the picture the roughness isn't only at the tip.. My interrogation is that get a very smooth finish when I use a quarter round bit or other cabinet bits. I wonder if it's a matter of settings or am I missing something here.. I would like to be able to use v-bits to make nice patterns playing on the Z axis.
  1. Improving surface fiinish
    By analogman in forum Benchtop Machines
    Last Post: 03-08-2016, 12:50 PM
  2. V25 PRO Advanced Rough/Adaptive Rough
    By RAF. in forum BobCad-Cam
    Last Post: 10-09-2013, 03:51 PM
  3. I need a better way to rough HY-80
    By AKcrabber in forum MetalWork Discussion
    Last Post: 07-25-2010, 09:10 PM
  4. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2010, 05:45 AM
