Originally Posted by
imitheo
Indeed, the judges will use optical sensors to check the speed of the tool when it travel along the X axis in 12m/min, then Y and then Z. The only thing they state it, is that it needs to pass through the sensors with 12m/min and the machine will have a 75mm to accelerate it to that speed. I didn't gave a thought for the acceleration, but yes, it's good to remember that the trick is in the acceleration rate of the machine. I intend to change the rapid to a lower value to mill it, just use the 12m/min to get the scores. It's not my fault that the judges didn't put something in the rules saying: "This rapid move needs to be used while milling", they did not, so i'll be using this agaisnt them.
Also it's the first competition of CNC machines we promote, so it's normal to start soft, to see where the engineers can go and what they can actually build. There are a hundred other rules about safety, milling capabilities, operations that the machine can realize, so it's not pointless.
Nevertheless, the point here is i should choose a stepper motor with low inductance? Also check the RPM x Torque curve of the stepper to see if it has the torque that the gantry requires to be moved at this speed ? One other issue is, this RPM x Torque curve does not count for acceleration, so i should be careful to accelerate my stepper too fast ? What are the issues this could cause?
