585,997 active members*
5,026 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad V29 Arcs sectioned
    Jun 2017
    6
    Hi, im programming with the BobCad V29 my laser machine, i use dxf file but when i have an arcs on my
    drawing the cutting was in section and not make the radius.
    I made my files in solidworks but when i open the dxf on Bobcad the arcs appear in sections.
    Apr 2008
    1577
    Quote Originally Posted by Daniel_Laser View Post
    Hi Daniel, try running the function "Reorganize" on your geometry after opening/merging in the dxf. It's also possible when exporting from Solidworks it is converting your arcs into segments. Check those settings as well. I'm not quite clear on the nature of your problem from the description you gave. Got a file sample you can upload?
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    Dec 2008
    4548
    Re: BobCad V29 Arcs sectioned
    In solidworks, when you choose to export and select dxf, choose "options". In the dialogue, select dwg/dxf and then in the dropdown, try R14 as the version.
    The file would help.
  1. Replies: 1
    Last Post: 01-07-2016, 04:11 AM
  2. Camsoft & Bobcad - problem with arcs
    By mbam in forum CamSoft Products
    Last Post: 08-26-2015, 07:19 PM
  3. Replies: 1
    Last Post: 09-26-2014, 02:27 AM
  4. Bobcad V24 & Camsoft & arcs
    By mbam in forum BobCad-Cam
    Last Post: 09-01-2012, 12:15 AM
  5. Sectioned linear rails ok or no?
    By Oracle_9 in forum Linear and Rotary Motion
    Last Post: 12-19-2005, 02:44 AM
