585,763 active members*
4,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > Upgrading the Syil X4 plus controller to enable win7
Results 1 to 6 of 6
    Jun 2017
    4
    Hi guys!
    I think i'm not the first, not the last and not alone with this.
    I just got the Syil X4 Plus from a friend of mine running the Mach3 on XP.
    I'd like to get everything from Fusion360 to Mach 3 to run under same windows, and as far as I know (That's no a lot) The parallel port adapter will not have any drivers available for anything higher than XP.
    Should I go ahead and upgrade the whole motion control to Hicon Integra or similar to get the system up to 2010's ???
    The xp is so weak and poor, that it makes more harm than good really.
    What are the options here, that I have to play with and what would be the best way to start the upgrading?
    Dec 2015
    20
    Re: Upgrading the Syil X4 plus controller to enable win7
    So... I've just ordered the Vital Hicon Integra for a Syil X4 Plus. It's going to be a difficult knitting job to get it set up in place. I'd be interested in what you have considered/done so far.
    Incidentally, I'm using a Warp9 ESS (Ethernet smooth stepper) with Mach3 on Windows 10 at the moment (have been for 6 months) & it's been fine. So if the OS is an issue for you then there is a less troublesome route you can take. Happy to explain more.
    Pete
    Jun 2017
    4
    Ok so today is THE day when the WinXP finally decided to die. We managed to get mach3 settings out of the pc, as we have Win7 running in parallel with the XP.
    Are we now facing the fact, that the X4 Plus is pretty much useless without the XP?
    How can we get the thing running in Win7 or higher?
    I'm pretty sure we need to update the motion controller to something like SmoothStepper ethernet, because we can't get the Mach3 to talk with the cnc in win7 64bit.
    Dec 2015
    20
    Quote Originally Posted by Rotary84 View Post
    I completed the Vital Integra upgrade. It's not too troublesome. Though a few gotchas. I'm running windows 10 with Mach4 presently.
    Prior to this I was using ESS on Windows 10 with mach3. It's very workable & all was fine until one of the boards supplied with the Syil failed - hence the upgrade.
    In summary - the upgrade required all boards in the Syil to be removed after labeling the wires. The front control display and buttons were replaced with a single steel plate (painted yellow obviously) with an e-stop button. Both relays were swapped out to be compatible with the Integra. A rotary encoder fitted to the spindle motor for threading.
    If you need pointers then I'm very happy to help.
    Pete
    Jun 2017
    4
    Quote Originally Posted by petemilligan View Post
    Pete
    I’m deffo interested, as the machine is truly a vital part of our current operations in our small workshop.
    Can you walk me through the steps of getting the parts needed and possibly share some config and build info?
    Dec 2015
    20
    I documented much of this. I'll hunt it down. In the meantime, here is a pic of it in the machine.
    Attached Thumbnails Attached Thumbnails IMG_20181029_205652.jpg   IMG_20181029_205632.jpg
  1. Enable PWM on Controller
    By John6310 in forum Hobbycnc (Products)
    Last Post: 10-02-2014, 12:09 AM
  2. Upgrading controller box
    By DAV II in forum Larken
    Last Post: 04-02-2014, 04:34 AM
  3. LC Plus Controller will not enable! URGENT
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 01-29-2014, 12:23 AM
  4. Add controller to enable e-cabinets software
    By Grant Nicholson in forum Controller & Computer Solutions
    Last Post: 02-02-2013, 03:16 PM
  5. Enable controller options
    By Dooda in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2009, 07:18 PM
