585,932 active members*
3,899 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Headstock lathe lubrication recommendation
    Oct 2005
    332
    Hello,
    I have start hearing a small noise in my headstock. I presume it is lack of lubrication (machine was bought second hand), and I am not sure if the headstock should be filled with lubrication, and if so, of what kind. I do not have machine manuals.
    Can someone provide a recommendation?
    Pictures attached.
    Thank you very much.
    Dec 2006
    584
    Re: Headstock lathe lubrication recommendation
    It would be helpful if you said the model of the lathe!!!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2005
    332
    Sorry. It is a Falcon 200
  1. Headstock Lubrication EZPath II
    By sabine in forum Bridgeport / Romi Lathes
    Last Post: 11-01-2014, 02:10 AM
  2. CNC lathe bed & headstock project
    By The Blight in forum Vertical Mill, Lathe Project Log
    Last Post: 01-29-2012, 01:36 AM
  3. CNC lathe bed & headstock project
    By The Blight in forum Mini Lathe
    Last Post: 04-12-2011, 10:36 PM
  4. Help with Lathe headstock screw...
    By Imacman in forum Canadian Club House
    Last Post: 08-31-2010, 03:10 AM
  5. Mini lathe headstock for Spindle
    By rgillam in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 01:59 AM
