machdrives.com announces the release of the new "BBC" six axis breakout board.
Specifically designed for use with Mach3 and inverter based spindle motors.
The VFD circuitry supports inverters with 0-10V and 0-5V analogue inputs and is fully opto-isolated to block inverter interference.
A new ratiometric 3 wire design gives very high accuracy speed control with a typical error of only 0.1% over the full speed range.
Slave axis support is now included for gantry routers
DIN rail mounting is now available as an option.
The user manual also includes connection and configuration details for the popular Chinese HY inverters.
Download BBC User Manual (PDF 2.1MB)
Features
- Supports up to six Step/Dir stepper or servo drives.
- High accuracy VFD support. 0-10V and 0-5V.
- Slave axis support for gantry routers.
- DIN rail mounting option.
- Standard LPT parallel port w/buffered I/O lines.
- Charge pump or simple enable support.
- E-Stop and Limit switch support
- Two 250V 5A general purpose relays.
- Three opto-isolated inputs for Touch probe etc.
- 9 LED indicators to simplify setup.
- Digital noise filtering on all control lines.
- 32 bit ARM CPU with safety interlock logic.
- Designed and manufactured in Australia.
- Dimensions 93mm x 79mm.
List price is AU $49.00 (approx US $37.00)
Attachment 365070
Attachment 365072
Attachment 365074
Attachment 365076
