585,987 active members*
4,220 visitors online*
Thread: Measure
    Apr 2012
    91
    Measure
    On your blog you have added an interesting tutorial for Warp. Thank you! However when calling "Measure" you show a graphic for this feature. Which TNG version has this included? Or is it yet to be published?
    Waiting "patiently"for this particular item.
    Mar 2017
    1312
    Re: Measure
    New version with "Measure" menu will be published in few minutes :-)
    But you can also use Warp in existing version. All you need are warp points which you can get using g-code below.
    Code:
    (name,Measure Surface, 1)
    (dlg,Position X, 3, 0, -10000, 10000)
    (dlg,Position Y, 3, 0, -10000, 10000)
    (dlg,Size X, 3, 40, 0, 10000)
    (dlg,Size Y, 3, 30, 0, 10000)
    (dlg,Step, 3, 5, 0, 10000)
    G90 (absolute mode)
    G94 (units per minute mode)
    F#<_speed_probe>
    G00 X#<_measure_surface-position_x> Y#<_measure_surface-position_y>
    M998
    #1 = #<_x>
    #2 = #<_y>
    #3 = #<_z>
    #11 = [#1 + #<_measure_surface-size_x>]
    #12 = [#2 + #<_measure_surface-size_y>]
    #21 = #1
    #22 = #2
    (logopen,MeasureSurface.txt)
    o200 while[#22 LE #12]
      o100 while[#21 LE #11]
        G00 X#21 Y#22
        G38.2 Z-10000
        G91
        G00 Z#<_sensor_zdist>
        G90
        #31 = [TOABSX[#21]]
        #32 = [TOABSY[#22]]
        #33 = [#<_probe_z> - #<_coord_system_z> - #<_g92_z> - #<_tool_offset_z>]
        (log,X#31 Y#32 Z#33)
        #21 = [#21 + #<_measure_surface-step>]
      o100 endwhile
      #22 = [#22 + #<_measure_surface-step>]
      o150 if[#22 LE #12]
        o100 while[#21 GT #1]
          #21 = [#21 - #<_measure_surface-step>]
          G00 X#21 Y#22
          G38.2 Z-10000
          G91
          G90
          #31 = [TOABSX[#21]]
          #32 = [TOABSY[#22]]
        o100 endwhile
      o150 endif
    o200 endwhile
    (logclose)
  1. has anyone seen my bracket I am trying to measure?
    By SomeWhatLost in forum Tormach Personal CNC Mill
    Last Post: 09-14-2013, 02:11 AM
  2. How to measure the tools DMU 50V/TNC 426
    By hiatec in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-11-2009, 11:07 AM
  3. z0 measure
    By albert.B in forum Fanuc
    Last Post: 08-29-2008, 01:14 PM
  4. Need measure
    By titoniks in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2006, 07:27 PM
  5. Measure Rpm
    By jhwatts in forum CNC Machine Related Electronics
    Last Post: 09-19-2005, 05:08 AM
