I am currently building a CNC from a Harbor Freight Mini Mill. It will be controlled with 3 steppers and an Ubuntu Linux box running EMC. (I am kind of a CNC hobbyist, but I do have things at work I could use it for)
I would like to create fairly simple items such as push-buttons, panels, and PCB cutting/drilling at first.
What CAD software is easy for beginners? I hate Auto-Cad (it does way too much and has a huge learning curve) and I need something simple to create the DXF files. I have a copy of TurboCAD that I have not tried yet. Is TurboCAD overkill? Is it easier to use than AutoCAD? Or should I use something simpler?
I have been noticing that some people use the Open Source Inkscape to vectorize Bitmaps, then convert those to g-code. Does it just use 2-colors to vectorize (black and white) or do different colors/shades correspond to different cutting depths?
Also what open-source/free-ware programs, if any, convert DXF to g-code? I have found Ace, which is freeware, but I hear it won't tell you the specific cuts it will make. I believe EMC would tell me what the g-code would do.
I would like to hear what other folks think on the software end of things so that I can narrow down the programs I will try.
-Brian
