585,717 active members*
3,747 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > 3D Printer / 3D Scanner Discussion > Why can't I find a single "parts focused" objective review of 3d printers?
Results 1 to 8 of 8
    Mar 2007
    37
    I'm preparing to invest in a nice FDM (FFF) printer soon and of course I'm primarily interested in the physical features of the output parts- layer bonding, materials, texture, support structure and it's effect on surface finish. These are all properties of the actual output part, and I wish I could find a review, author, or organization that would evaluate the output part blindly on these merits alone rather than all the superfluous details of the machine itself (eg. interior lighting, interface, software, etc.). Not that machine details are totally inconsequential but at the end of the day pretty much the only thing that matters to me is the physical performance characteristics of my parts. I wish someone would do a review where the same file is printed on a collection of popular printers and the reviewer(s) only get the resultant part to base their entire assessment. Things like strength, accuracy, surface finish, and material matter to me, it doesn't matter so much how we got there. Sure there are some details like how big a part you can make or how long it took to make it that are relevant, but I'd like to take those out of the equation so that we can just talk about the result objectively.
    The same double-blind testing of wines I found pretty revealing and I can't help but think we might see some similar results in this industry- or even better, a distinct winner in the "bang for the buck" category when we're just looking at parts. Tests could/should include destructive testing to evaluate layer strength and flex/toughness, heat resistance.
    Anyway, if anyone has seen some reviews like this I'd LOVE to hear from you! Maybe we could organize a test here on the forum?
    Apr 2004
    5734
    Re: Why can't I find a single "parts focused" objective review of 3d printers?
    The trouble with relying on individual users for reviews of their machines is that nobody's getting one each of every one that's made and comparing them head-to-head. It takes an organization like Consumer Reports to do something like that. The closest I've seen anyone come is Make Magazine, which puts out an annual list of best printers (heavily skewed toward FDM-type printers): 3D Printer Buyer's Guide | Make: DIY Projects and Ideas for Makers
    Most of these machines are pretty similar to one another, and the differences are fairly subtle, involving how well they handle various different filaments, and how they keep the parts from warping when printed in some of them. You really need to define exactly what you want to do, which materials you want to use, and what features you need - heated bed? dual nozzles for support materials? capacity to handle flex filament? large work envelope? good manufacturer support? - before you can make a meaningful choice.
    Andrew Werby
    Website
    Mar 2007
    37
    Thanks- and I agree, the differences can be subtle. I had this same conversation elsewhere and wear and tear on the machine was brought up as a valid strong contributing factor. I think the cool thing about such a comparison is that you could design a "test part" that is intentionally challenging to build due to various factors and simply request that a sample part be printed on assorted printer manufacturers to the best of their ability, and using a common material like PLA. If it has a heated bed- great! that should be reflected in the result an count toward the score. Dual nozzles? great! Use dissolving support and reap the rewards! Don't have any of these? Well, your resultant part/score is likely to suffer. Also, since many machines spec their own materials, I guess that would play a role too.
    Apr 2004
    5734
    You don't need a heated bed for PLA, but it's pretty essential for ABS. Some parts print fine without any support; others won't work at all. Some machines work fine for a while, then stop making parts to spec. The trouble with your idea is that the manufacturers whose machines are suitable for that part might respond, but the others won't. But maybe I'm being too negative - go ahead and design your part, send it to a lot of folks, and see how it goes. Let us know who wins, okay?
    Andrew Werby
    Website
    Mar 2007
    37
    Well, I guess you could look at it as machines that COULD produce a good result would want to tout that as an accomplishment, and no response would just suggest that machine isn't up to snuff. I actually think a better scenario would be to focus on unbiased customers running these parts- that way results would be more validated- also preferred because machines would have more realistic wear & tear.
    I don't mean to focus on the assorted details I mentioned(eg. Heated bed), only that all these features as well as other more subtle design details can effect the end result.
    Jan 2018
    4
    The thing is way more simple than you might think: It needs very little effort to get a good print despite some time tweaking what you have.
    I am telling this, after building a dozen printers from 500€ to 4000€. Then I got sent a "CR10" for free and did some minor modifications to it (nothing special, just switching to key components to stuff I like, before even trying the stock - switched controllerboard, hotend, cooling, belt) and I am astonished by the quality I get out of this cheap-ass printer.
    After all, it is laying down a hot sausage of molten plastic (in most cases) 0.4mm thickness. Not more, not less. The only question is: How comfortable or fast can you lay that sausage down precisely
    - - - Updated - - -
    May 2015
    1422
    It's why reference parts like the benchy boat and various torture tests were designed. But, really, the filament is the limitation in most cases.
    Aug 2019
    5
    Hi guys! As for me, the best 3d printer for beginners is Wanhao Duplicator i3 mini.
    https://www.wanhaousa.net/product-pa...icator-i3-mini
    The printer costs less than $ 200. But despite the simplicity of the design and low price, it makes high-quality models, especially if they are from PLA.
    Here are some of the main pros and cons: Nothing needs to be further customized and invented. To start the printer and print the model you don't need any special knowledge. But this printer doesn't have any heated platform, the case is open and the print area is small but it still large enough for most projects.
    If you want to know more about how to choose the 3d printer and make the right decision, I will recommend reading this article. It was very helpful to me.
    Good luck with your choice!
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Cant find "loose" linear rail for floating head
    By Beefy in forum Waterjet General Topics
    Last Post: 11-25-2010, 03:36 PM
  3. "Simple" single tool change feature?
    By tubeguy in forum BobCad-Cam
    Last Post: 10-14-2010, 08:48 PM
  4. specialized, single-purpose CNC for making "talking strips": general building tips?
    By Glass-Giant in forum Mechanical Calculations/Engineering Design
    Last Post: 04-09-2007, 10:20 PM
  5. "Fancy" single line font
    By DAB_Design in forum G-Code Programing
    Last Post: 04-25-2005, 09:04 PM
