Hi
I need some help with my mazak vcn 530c with smooth control, I'm milling a large and long piece of steel, it is so long it has to stick out of the machine . Then I get a problem with tool switching. When I make a tool switch, the machine puts itself in Y0, but since the material is as wide and long as it is, this is not ideal because it will bang the material into the machine.
Have found that I have to do something in the parameter list, have to change parameter numbers in RB19, but have done so, but the machine is still in Y0, talked to the vendor of the machine but did not get any wiser
Do any of you have any ideas?
