Hello,
I'm looking at this CNC machine and would like to ask a few questions. I have read that lots of these come with hacked version of Mach 3. Can I use a bought version of the new Mach 4 with this machine.
Also I'm trying to figure out if I can run this using USB and windows 10 or do I need to use something different or the SD card slot on the DSP controller? I would like to use this to cut small aluminum molds
so I can test some seal designs. How was it getting this up and running smoothly and accurate? Also I'm not sure what a water sink cooling system is? Does this come with a water pump? Any other advice
or comments you would be great.
ChinaCNCzone DSP CNC 6040 Router 3 Axis 4 Axis with 1500W /2200W Spindle and Water Sink Cooling System Z axis 105mm
Thank you for the help.
Dave
