584,842 active members*
4,295 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Spindle speed - faster = better?
    I have a CNC3020T which has a 300W, 8000RPM spindle.
    I want to use this machine principally for making PCBs. I made a board with it today and the board is perfectly usable but the edges of the copper were quite burred. Cleaned up OK with a green scourer and some emery.
    Would a faster spindle give a better, cleaner cut, or just increase the possible feed speed?
    Re: Spindle speed - faster = better?
    Quote Originally Posted by jimthurgood View Post
    I normal run mine around 20K however I'd prefer it to run at 50K but your best bet is to find the "sweet" spot for your cutter by doing a number of cuts at different feeds side by side, preferably in a zig zag pattern and you will see a marked difference in the quality of cut once you find it, also use a cutting oil of some sort, I use coconut oil and works remarkably well smeared across the top, you will find that you will more than likely need to slow down the feed for your spindle.
    I have some GCode for just this that I run on all my pub cutters that I'll post when I get into work
    Stephen...
    Sent from my iPad using Tapatalk
  1. faster spindle... Do I need to adjust feeds??
    By Us ill in forum Chinese Machines
    Last Post: 07-31-2014, 05:46 AM
  2. I need a faster spindle
    By Hood in forum BobCad-Cam
    Last Post: 02-01-2014, 08:57 PM
  3. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  4. Replies: 1
    Last Post: 03-05-2011, 06:58 AM
  5. Why is speed faster than I set
    By monte55 in forum Machines running Mach Software
    Last Post: 11-04-2006, 05:48 PM
