585,712 active members*
4,170 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle will not turn below 225 rpm
Results 1 to 3 of 3
    Jul 2016
    6
    Exclamation Spindle will not turn below 225 rpm
    I'm having issues with a Baldor ( ZD18H220Y/D 15H 10K rpm) on my 1996 6030 Fadal. I suspect it is related to a low speed issue. The spindle will run and stop as normal, but I can't get the spindle to turn slower than 225 rpm. I first noticed the issue when it would not index for a tool change. I can see the lights on the controller alternating between fwd and rev while trying to index the spindle for a tool change, but the spindle doesn't move. Eventually it gives up and shows "Orientation Failure". I did replace the encoder on the motor and it didn't make a difference. I also tested the hall effect switch and it is working also. Any ideas?
    Apr 2005
    1194
    Re: Spindle will not turn below 225 rpm
    Orientation factor is set in your SETP area but I dont think that will help you. Is this a new to you machine?
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Jul 2016
    6
    I've had the machine since it was new. I did verify the orientation factor hasn't changed.
    I suspect it is the Baldor controller. I hoped that someone else had the same issue and it was less expensive fix than repairing or replacing the motor controller. Pratec charges $1100 plus parts, which I think is a bit high when I can buy a new upgraded controller for $2500.
  1. how to turn on spindle while mill spindle is on!!
    By the mill kid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2010, 08:08 PM
  2. Spindle won't turn on
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2009, 12:32 AM
  3. help spindle does't turn
    By napa55 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2009, 06:51 PM
  4. T1..why does the spindle not turn?
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-06-2008, 03:32 AM
  5. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
