585,877 active members*
3,968 visitors online*
    Dec 2004
    26
    Gildemeister CTX 400 with blank monitor
    Hello,
    I just got a Gildemeister CTX400. When I power it up the monitor doesn´t show anything, The previous owner told me that his technicians had pulled the battery pack out of the ZP186 module in addition to pulling all the other modules out and putting them back in the EPL2.2. Currently the ZP186 module has L3, L4, L5, L6 red and the SP/FG, and BFI modules have L1, L2, L3, L4 red. I´ve tested the voltage to the monitor it is recieving 220v and the 15 pin DB conector is conected to the monitor and the other en 9 pin DB is conected to the SP/FG module. My question is if the eprom needs to be flashed again to get the monitor running if so can anyone help with the steps to do so.
    Bradley
    May 2013
    Re: Gildemeister CTX 400 with blank monitor
    Hello,
    Did you resolve this issue? I have the same problem.
    Dead screen on power up. I had been thinking the CRT had just failed.
    Appreciate any advice.
    Paul
    Dec 2004
    26
    Quote Originally Posted by flynno83 View Post
    Hello,
    Paul
    Hi Paul,
    I haven't resolved the problem yet. I did contact DMG Mori. They sugguested I change the battery and reload the parameters. They also sent me a standard set of parameters for the CTX 400. I'm trying to find out if there is a way to load the parameters through the rs232 port on the zp186 module. However, I'm not sure how to tell it to receive the parameters since the monitor is dead. Maybe someone else knows how to do that.
    Regards,
    Bradley
    Apr 2009
    18
    Hi
    Apr 2009
    18
    Hi Bradley
    I am cnc machine installer and work with Siemens and fanuc system but my friend buy ctx400 Epl2 gieldmaiester .I need it's all parameters please send me to [email protected]
    Jun 2011
    61
    Hi Bradley , did you get your CTx 400 running after all ? Im in that boat right now , any help would be appreciated . Thanks and all the best Harry
  1. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  2. U10M spindle load monitor and monitor mode
    By myhäje in forum Okuma
    Last Post: 02-21-2017, 08:45 AM
  3. Gildemeister NEF CT-60
    By ragunath400 in forum Controller & Computer Solutions
    Last Post: 05-11-2014, 08:16 AM
  4. Gildemeister T-42
    By lonely in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2008, 01:57 AM
