584,841 active members*
4,548 visitors online*
Results 1 to 10 of 10
    Jul 2005
    2415
    New Hand Control Pendant for MACH
    CandCNC announces a new 28 function pendant for our MP1000 Interface boxes . Named the MPG101B, the small hand-held unit features a Jog Stick that allows 2 axis Proportional jogging of either XY or ZA (selectable). Three Jog Ranges (Fast, Slow and Single Step "Bump" modes) make setup and positioning easy. The control uses 6 input signals of a parallel port for high speed response to MACH. The first version plugs into the front (DB9) connector of any of our MP1000 series THC, Spindle Speed or Basic units.
    A universal port adapter will be available in about 30 days. Adapters for use with our existing series of MINI-IO Port2 cards (or complete Combo/SuperCombo boxes) will appear in 2-3 weeks.
    The unit ships with a 25' cable, MACH3 Plug-in with on-screen configuration and instruction manual. Install takes 10 min. See Http://www.CandCNC.com/MPG101.htm for more information and pictures.
    Jul 2005
    2415
    MPG101B Front Decals
    Several requests for the layout of the Plasma version (THC) for the MPG101B so here they both are:
    Sep 2005
    Pendant
    Will this new pendant work with the Campbell Design breakout board??
    Jul 2005
    2415
    Quote Originally Posted by techmation View Post
    The Campbell Card is a port 1 breakout and only has 5 inputs open (which are normally used for Homes / limits). THe MPG101B is designed to work on a 2nd parallel port with MACH. To use it with the Campbell or any other port 1 breakout you will need to install a port 2 and then order the Universal Port Input adapter which will screw to the 2nd parallel port (actually a form of breakout too) and let you plug the 9 pin cable from the MPG101B in AND get access to the other port two signals (5 more). It's not isolated inputs (MPG101B are buffered from the unit).
    We will have the Universal Port Input cards available in a couple of weeks.
    Jun 2009
    55
    Hello Torchhead
    Can you give us a preview of the New Pendant? New look? New functions?
    Jan 2008
    77
    Is there an update on the MPG202?
    Mar 2006
    489
    No offense Tom, but paying someone to make an attractive and functional faceplate would probably pay for itself in sales. Looks matter, and that faceplate...well...she ugly.
    Jul 2005
    2415
    Quote Originally Posted by pofo View Post
    The scope of the project has changed considerably. There will be two versions of the Hand Control. The 200 will have proportional jogstick and membrane keypad and be similar to the older MPG101B in functions and pricing. The 400 will have a back lighted graphics LCD, full MACH control including entering G-code (MDI) commands and full readouts (DRO's) for both Router/mill type cutting and interface for our screen based DTHC products (display/set all DTHC parameters.) It will be like having a hand-held control panel you can control with one hand. The MPG400 will be priced at $350 with discounts when combined with our products.
    We have decided to use high speed noise immune RS485 communications to/from the PC that supports up to 1 MHZ at up to 300 ft across standard UTP (unshielded) . The Ethernet approach we started with was noble but way more complex and expensive for a tethered hand controller than it had to be. Some of the controls on both units will be slide type pots for things like Feed rate override and jog speeds. Both units will work with MACH3 and plug to the PC directly so are largely independent of hardware. Special functions like the display and setting of Torch Height parameters and Spindle Speed RPM and setting will be specific to our products for those functions Both units will be able to run preset or custom macros (written by the user if desired).
    I don't have any drawings or photos yet but I do have a case and custom keypads selected.
    The time line is for us to have working prototypes in October and shipping production units in November.
    TOM caudle
    www.CandCNC.com
    Jul 2005
    2415
    Quote Originally Posted by fatal-exception View Post
    I assume you are referring to our MPG101B
    No offense taken. Everybody has a concept of what a hand control should do and look like. When we do a design we use the following criteria:
    1. Functionality. Is it usable to run a table and put full control of the table in the operators hand. It's one thing to have a "jog control" It's another to have enough functions that you don't have to constantly run back and forth to the keyboard to be able to run a job. Does it make the job of running a CNC machine better, faster, easier? The vast majority of Hand Control advantages come on larger CNC tables where its difficult to have the operatior screen close to you and interface with (see/touch/move) the material or position of the cutter at the same time. Can you move to the end of an 8ft (or longer) table and still run the machine?
    2. Ease of use. Do a design that does not require two hands to twist switches, spin knobs or change modes. Have enough single function buttons that you don't need a manual to figure out how to use it. Single handed operation (because man was born with only two arms/hands) lets you have one arm available to interact with the table/material, etc
    3. Reliability. Does it work in noisy and adverse conditions. Will it last in the shop. Do we use it in our daily production cutting so we know the kind of actions you have to perform over and over?.
    4. Cost. If packaging doubles the price is it worth it for "looks"? One problem with this market is that the volume will not justify things like custom cases, custom molded components, etc. You can easily get thousands of dollars in tooling and prototypes that you have to spread over a few hundred units in sales. The only way to get pricing down on some components is to buy them in bulk up front. It then means a lot of your money sitting in boxes on the shelf over a long period. It doesn't sound too bad to add a few dollars to your cost but the raw cost of a component is only part of the equation. If you do this as a business (and want to stay in business) then you know that you have to multiply each penny of raw cost by a factor to account for all the "hidden" costs.
    While beauty is an eye feature it's not on the top of the list. :rainfro: I'm open for suggestions. Just point out a design(s) you think has the characteristics of beauty you find desirable in the same price range for me to study.
    TOM caudle
    www.CandCNC.com
    Jan 2008
    77
    Thank you for the update.
    My only input as one that would use it for a 4 axis mill is to make as many keys as possible, programmable, rather than assigned; allowing the user to decide what functions are on the pendant and where they are located.
    I can always make my own overlay.
    Waiting in earnest,
    Cheers.
  1. New Pendant control
    By wcarrothers in forum DIY CNC Router Table Machines
    Last Post: 01-03-2008, 06:13 PM
  2. 0-10V output control with Mach 3?
    By fatal-exception in forum Mach Mill
    Last Post: 01-11-2007, 07:39 PM
  3. Des Plaines, IL Needs Help With Mach 3 and Control Box
    By carveceltic in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2006, 07:15 AM
  4. How would you use Mach to control a bender?
    By panozeng in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2006, 06:40 AM
  5. coverting from Right-hand to left-hand coordinate system
    By eltonr in forum Uncategorised CAM Discussion
    Last Post: 10-15-2004, 02:40 AM
