585,712 active members*
4,014 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > NEW TO THE PAGE HERE IS MY HOME BUILT METAL CNC
Page 1 of 3 123
Results 1 to 20 of 60
    Oct 2016
    128
    I just joined. I have looked at the page a few times for ideas over the past year. I figured I would share my creation with everyone here. Feel free to ask any questions. I will post pics from my phone in a few.
    Oct 2016
    128
    Re: NEW TO THE PAGE HERE IS MY HOME BUILT METAL CNC
    Tried to upload videos but it will not let me.
    Oct 2016
    128
    My control wiring is a mess right now because I just switched a bunch of stuff from steppers to servos. But I'm running Mach 3 with a smooth stepper no breakout board other than the smooth stepper. A hertz 2.2 spindle with an er25 collet and a delta vfd. I have thk shs 35 rails on my Y axis thk srs30 rails for my X axis and a double thk kr45 actuator for my z axis. This is the 4th machine I've built now to achieve the results I've been looking for in metal cutting and surface finishing. Im able to machine aluminum, steel, and stainless. I've finally gotten the machine stable enough to run aluminum with an 1/8 step down at 250 ipm at 15000 rpm
    Oct 2016
    128
    this is my machine that used prior to my new one and also what I used to machine all the pieces for my new machine as well.
    Oct 2016
    128
    Here's a link to the machine in use.
    https://youtu.be/1zOghXwb-SU
    Oct 2016
    128
    https://youtu.be/dxaARzR56HA
    Oct 2016
    128
    New tool tray to keep it all off the floor
    Oct 2016
    128
    New video
    https://youtu.be/tS5AvT-Siys
    Oct 2016
    128
    Dec 2014
    12
    Great work! Interested to hear your impression on the servos you used. Which did you pick? Seems similar to the ones posted on aliexpress.
    Oct 2016
    128
    Quote Originally Posted by CanonGuy View Post
    Yes there Chinese servos. 3000 rated rpm .75kw. I have one that keeps losing position when I run over 300ipm but I believe it's the belt drive skipping a tooth from the torque. I'm waiting on my last zeromax coupler and they will all be direct drive. Then I'll know for sure what the problem was. Also I had to change a bunch of settings in Mach for my computer to be able to talk to the machine fast enough.
    Oct 2016
    128
    They are KRS servos and drives, 220v 3phase
    Nov 2012
    29
    Could you tell us more about Mach 3 settings?
    Oct 2016
    128
    Quote Originally Posted by John1987 View Post
    I had to calculate the steps and match it with the correct MHz for the drive in the settings for my ess. Also had to set the buffer length to 4mhz. I also changed the step to 1 and the signal to 2 in the motor tuning. I'll have to think of what else I changed.
    Oct 2016
    128
    Machining a 26x12x1 steel plate. The largest I've ever attempted
    Sep 2006
    6463
    Quote Originally Posted by dillonfitz View Post
    Hi.......yeacccchhhh.....I shuddered when I saw this pic, actually physically sick........that has to be the messiest machine I have ever seen...........do you normally work like this or was it the maid's day off......and the digital caliper and collets lying on top of all the stuff.....house keeping is not your cup of tea I see.
    Ian.
    Oct 2016
    128
    Quote Originally Posted by handlewanker View Post
    Ian.
    Well good thing you don't have to look at it.
    I said it was my old machine. So it's now dead in the corner with no care to do anything except scrap it. Lol
    Oct 2016
    128
    Never had these results when running steel.
    Used a sandvik 6flute super high helix finishing bit
    May 2015
    Dillonfitz, great machine. I built a similar style machine a while ago out of Epoxy Granite. I was thinking of using similar motors, although I'd prefer to use them in analog control mode with feedback to linuxcnc. How do you find the step direction control?
    Oct 2016
    128
    Quote Originally Posted by chrisrusk View Post
    Dillonfitz, great machine by the way. I built a similar style machine a while ago out of Epoxy Granite. I was thinking of using similar motors, although I'd prefer to use them in analog control mode with feedback to linuxcnc. How do you find the step direction control?
    Thanks.
    The drives that I use use the step and dir outputs just like stepper drives. There's a parameter within the servo drive to set the input to digital and also within he smooth stepper confit I unchecked the step/dir box and checked the cw/ccw
Page 1 of 3 123
  1. Featured Image on showcase home page.
    By coykiesaol in forum Autodesk
    Last Post: 11-30-2010, 08:24 AM
  2. Home page not loading
    By MrWild in forum Community Club House
    Last Post: 01-16-2008, 03:40 PM
