585,992 active members*
5,238 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > NEW TO THE PAGE HERE IS MY HOME BUILT METAL CNC
Page 3 of 3 123
Results 41 to 60 of 60
  1. #41
    Apr 2008
    204
    Re: NEW TO THE PAGE HERE IS MY HOME BUILT METAL CNC
    https://www.zoro.com/ebm-papst-blowe...saAnC6EALw_wcB
    - - - Updated - - -
    what did you use
  2. #42
    Oct 2016
    128
    Quote Originally Posted by davy182 View Post
    - - - Updated - - -
    what did you use
    Ok cool. That's similar to what I ordered. And you blow the air into the motor or suck it through?
  3. #43
    Oct 2016
    128
    just changed my coolant with "TRIM SC520" and this is some thick stuff. I only mixed it 5:1. Anyone else use it? I normally use astrocut synthetic
  4. #44
    Mar 2017
    5
    How funny is this?
    This is my setup...
  5. #45
    Oct 2016
    128
    Quote Originally Posted by TheTimeKeeper View Post
    How funny is this?
    This is my setup...
    Lol. Nice! Idk if you've used it yet or not but I switched from my hertz spindle to this and it was a night and day difference. I love it other than the fact that it uses a special ISO 30 pull stud
  6. #46
    Mar 2017
    5
    Yes, i have been using it for about 6 months. This pic was taken while still in the build stage.
    It is using Clearpath servos on all axis and Mach3 with ESS/MB2.
    Pull studs were an issue, but now i just purchase ones that are slightly larger and machine them down in the lathe.
    I will post some more pics/vids later.
  7. #47
    Oct 2016
    128
    Oh gotcha. I did find holder that fit these spindles. Idk if you need anymore but there made by armada tool
    Amana Tool HO-112 50mm ISO30 Tool Holder https://www.amazon.com/dp/B000P4QK6Y..._fwOIzbZYVBJW8
    And cmt
    CMT 183.250.01 Chuck with "ER32" Precision Collet, ISO30 Shank, Right-Hand rotation https://www.amazon.com/dp/B000P4LJ60..._svOIzb11RZYYQ
  8. #48
    Mar 2017
    5
    I have looked at those, but they are a bit pricey...
    I've been using some of these for the light work:
    ISO30 ER32 G2.5 24000rpm Precision Balance Collet Chuck Holder CNC Toolholder | eBay
  9. #49
    Oct 2016
    128
  10. #50
    Oct 2016
    128
    Does anyone use shrink fit holders?
  11. #51
    Oct 2016
    128
    Finally got the tool changer functional and almost done. I ended up swapping motors again. I didn't want to worry about heat so I put a newer Colombo motor on that has an hsk 40 taper.
    https://youtu.be/C1QN8uWB2gI
  12. #52
    Jun 2005
    1730
    Very nice implementation on the tool changer. I like how the tools and holders move way out of the way at the end of the cycle, very well done.
    Russ
  13. #53
    Oct 2016
    128
    Quote Originally Posted by CNCMAN172 View Post
    Russ
    Thank you. I still have to o make some kind of cover for the top of the holders. I never thought too much about it but being hsk holders, there a hole in the middle for the fingers on the motor. That's a great place for shavings to pack in and no way to get them out.
  14. #54
    Apr 2015
    113
    what a wicked machine.
    Luthier/Woodworker/Machinist in NS, Canada.
  15. #55
    Oct 2016
    128
    Quote Originally Posted by jahnj0584 View Post
    Thanks a lot. I'm happy that I've been able to get it where it's at.
  16. #56
    Oct 2016
    128
    It’s been a while since I’ve posed anything so I figured I’d take a video while I’m sitting here watching this thing run.
    This is a 1/4” depth of cut at 11000 rpm with a 10mm bit
    https://www.youtube.com/watch?v=6x8MKJgsdHw&sns=em
  17. #57
    Oct 2016
    128
  18. #58
    Mar 2017
    926
    How funny is this?
    This is my setup...
    How are you running the 380v spindle? Do you have a 380v outlet in your work area or are you using some kind of transformer or VFD that can output 380v from a 220v input? Or are you just limiting your top speed to whatever it can reach at 220v?
  19. #59
    Oct 2016
    128
    Quote Originally Posted by Goemon View Post
    I run a transformer but I also have another vfd drive that’s 220v single phase input and 380v 3 phase output if you need one. It’s my setup that I used before. My motor now is 460v so I had to get a different drive.
  20. #60
    Jun 2011
    692
    FYI the spindle should still be able to run at top speed when run at a lower voltage, just with less power than when run with the correct voltage. For example, if you've got a 380v 8HP spindle that has a rated speed of 18k and max speed of 24k and rated current of 14A, if you ran it at 220V, you would use a 220v VFD (don't try using a VFD rated for a different voltage than what you've got, it'll fault,) you would set the current to the same 14A, but set the nameplate speed (or whatever it's called in your VFD, the speed where you reach max volts,) to 10,400 RPM (18k * 220/380,) max RPM to 24k, and your max power would be 4.6HP. Torque up to 10,400 RPM would be the same as the constant torque of the spindle running on 380 (which would be constant torque up to 18k.) You would then have constant 4.6HP between 10,400 and 24k RPM.
    This only applies to water cooled and forced air cooled spindles. Spindles that have a fan on the spindle shaft (most air-cooled non-ATC spindles) would need additional derating due to reduced cooling at lower RPM's.
Page 3 of 3 123
  1. Featured Image on showcase home page.
    By coykiesaol in forum Autodesk
    Last Post: 11-30-2010, 08:24 AM
  2. Home page not loading
    By MrWild in forum Community Club House
    Last Post: 01-16-2008, 03:40 PM
