I just joined. I have looked at the page a few times for ideas over the past year. I figured I would share my creation with everyone here. Feel free to ask any questions. I will post pics from my phone in a few.
Tried to upload videos but it will not let me.
My control wiring is a mess right now because I just switched a bunch of stuff from steppers to servos. But I'm running Mach 3 with a smooth stepper no breakout board other than the smooth stepper. A hertz 2.2 spindle with an er25 collet and a delta vfd. I have thk shs 35 rails on my Y axis thk srs30 rails for my X axis and a double thk kr45 actuator for my z axis. This is the 4th machine I've built now to achieve the results I've been looking for in metal cutting and surface finishing. Im able to machine aluminum, steel, and stainless. I've finally gotten the machine stable enough to run aluminum with an 1/8 step down at 250 ipm at 15000 rpm
this is my machine that used prior to my new one and also what I used to machine all the pieces for my new machine as well.
Hi.......yeacccchhhh.....I shuddered when I saw this pic, actually physically sick........that has to be the messiest machine I have ever seen...........do you normally work like this or was it the maid's day off......and the digital caliper and collets lying on top of all the stuff.....house keeping is not your cup of tea I see.
Ian.
Here's a link to the machine in use.
https://youtu.be/1zOghXwb-SU
https://youtu.be/dxaARzR56HA
New tool tray to keep it all off the floor
New video
https://youtu.be/tS5AvT-Siys
Great work! Interested to hear your impression on the servos you used. Which did you pick? Seems similar to the ones posted on aliexpress.
Yes there Chinese servos. 3000 rated rpm .75kw. I have one that keeps losing position when I run over 300ipm but I believe it's the belt drive skipping a tooth from the torque. I'm waiting on my last zeromax coupler and they will all be direct drive. Then I'll know for sure what the problem was. Also I had to change a bunch of settings in Mach for my computer to be able to talk to the machine fast enough.
Could you tell us more about Mach 3 settings?
I had to calculate the steps and match it with the correct MHz for the drive in the settings for my ess. Also had to set the buffer length to 4mhz. I also changed the step to 1 and the signal to 2 in the motor tuning. I'll have to think of what else I changed.
Machining a 26x12x1 steel plate. The largest I've ever attempted
Never had these results when running steel.
Used a sandvik 6flute super high helix finishing bit
Cutting a new motor mount to bolt to the ball screw bearing block. Starting with a 6x6x2 block of 6061. I will put up a pic when it's done cutting.
Cool machine! Looks very capable. I'm also using the KR actuators on my Z and they're working really well. Do you find any difference in accuracy of the parts for the different axis?
Sent from my SM-G900I using Tapatalk
