585,722 active members*
3,976 visitors online*
Results 1 to 7 of 7
    Mar 2005
    10
    Problem with Brother Wire EDM
    I just bought Brother HS3100 wire EDM machine at auction and after powering it up everything was fine for few days. Than one morning I turned it on and the screen and the keyboard were dead.(except green ON and red OFF lights).The rest of the machine was ON. (fans and all the electronics inside the machine were running). I checked all the fuses and I found one (3Amp fast glass) blown inside the control. And now, after replacing that fuse when I try to turn on the machine , it powers up but after 5 seconds it turns itself off. Same thing happens when I disconnect CRT monitor.(no difference) Is it possible that the monitor is bad ,and there is no confirmation to control board that the monitor is working and that's why machine is shutting off ? Any idea? When I remove the replaced fuse machine powers up but the keybord and monitor are still not working. Thanks for any response! One more thing. This machine is wired for 240 V. It has other 4 options (200, 208, 220 and 230 V) In my place voltage varies from 205 to 215 V) Would that be a problem?
    Oct 2003
    41
    The electrical variance could well be enough to cause problems. On most machines they want it within 5%, yours is out of that range. Another common problem on used machines is the battery that backs up the operating system is dead. When you power it off it loses it's memory, and you have to re-load the software and all the parameters.
    I never shut my machines off, the control, servos, and pumps are constantly running.
    Cheers!
    Roy Solomon
    Jan 2006
    104
    you should wire it for 208 volts.....
    it sounds like the power company is supplying you with 208 3 phase....
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Oct 2006
    100
    Re: Problem with Brother Wire EDM
    Quote Originally Posted by roysol View Post
    Cheers!
    Roy Solomon
    Roy,Do you the procedure for reloading software and parameters on the Brother HS 3100 ?
    Oct 2006
    100
    Brother HS 3100
    Does any one Know the MFG and a part number for the wire feed motor #2.
    The motor has a sticker from Brother
    I have this part number from Charmliies
    M48B-Z25726001
    I'm in a big problem
    I want an old machine manual (Brother HS-3100 wire cut machine)
    Please if you know any source I can find it from
    hi dude, did you find the manual?
  1. BROTHER HS-3600 WIRE EDM
    By MAN39ER in forum EDM Discussion General Topics
    Last Post: 08-21-2022, 06:54 PM
  2. Brother Wire EDM HS100
    By bsjoelund in forum Machinery Manuals / Brochures
    Last Post: 09-12-2020, 07:21 AM
  3. Want Brother HS-70A or HS-70AM wire EDM
    By NoSurprise in forum Want To Buy...Need help!
    Last Post: 07-17-2012, 06:59 PM
  4. Brother HS-70a wire EDM Tech files?
    By RHoffer in forum EDM Discussion General Topics
    Last Post: 10-31-2008, 10:54 PM
  5. Brother Wire Edm
    By JINX222 in forum Waterjet General Topics
    Last Post: 01-28-2007, 10:46 AM
