585,759 active members*
4,004 visitors online*
Results 1 to 10 of 10
    Jan 2013
    73
    Chiron FZ12W 810m GA3 error codes help
    Good day,
    I have some error codes if someone can help.
    The machine is 1996 Chiron FZ12W with 2x 4th axis and renishaw tool measuring probe.
    When I home the machine only X,Y,Z home, B and B1 doesnt home.
    I still havent been able to turn on the spindle.
    Im not sure if I need to set which tool is in the spindle (cause one tool is in the spindle right now) and how to set which side of the table is under the spindle.
    The machine battery was dead and after loading the parameters back I cant get rid of the alarms:
    PLC ALARME:
    6056 ENDSH.WERKZEUGARME UNTEN
    6062 FEHLER TEMPERATURKOMPENSATION
    6044 REIHENF.REF.PUNKTE ANFAHREN FALSCH
    PLC MELDUNGEN:
    7011 REFERENZPUNKTE NICHT ANGEFAHREN
    7016 WERKSTUECKWECHSLER NICHT IN GRUNDST
    7036
    If anyone have Chiron FZ12W manuals in PDF and if you can send on my Email please contact me.
    Any help is welcome.
    Thank you.
    Mar 2015
    7
    Re: Chiron FZ12W 810m GA3 error codes help
    You still need this errors?
    Jan 2013
    73
    Quote Originally Posted by gyzoli View Post
    No, its solved.
    The only error left is:
    Thank you.
    Jan 2019
    Hi, I have chiron fz 12 siemens 810, when I bought it the battery was dead. now I have no parameters, if someone can help me I would be grateful.
    Dec 2006
    I have a Fz 18, also with siemens 810. I have a cd/floppy with all the parameters, but not manuals. How can I help you?
    May 2019
    10
    Hola, has podido solucionar el problema que tenias? yo tengo la misma maquina que tu y me a pasado lo mismo y no encuentro los parametros en ningun sitio te agradeceria que si pudistes solucionarlo con tu maquina me ayudaras con la mia. Gracias de ante mano
    Jun 2018
    20
    Re: Chiron Fis the problem solved?
    Quote Originally Posted by Adnanhaha View Post
    May 2019
    10
    Quote Originally Posted by kovboyyyy View Post
    no se ha resuelto todavia el problema
    May 2019
    10
    Al final consegui los parametros del cnc, entro en borrado inicial borro memoria, pongo los bits de ent-sal de datos como dice el manual de siemens cargo ta1 y ta2 bien formateo memoria de usuario y memoria de alarmas vuelvo a establecer bits de comunicacion y empiezo a transferir pcp sale en la pantalla del cnc y parece que todo valla bien asta los 8799 bits que se para desaparece pcp de la pantalla de cnc y no sale ningun error en ningun sitio, he probado con velocidades de baudios de 300, 1200, 9600 y siempre pasa lo mismo he probado con otro cable de comunicacion y los mismo he probado a cargar el pcp solo sin cargar ta1 y ta2 y se para la transmision igual a los mismos bits, he cargado todos los parametros ta1, ta2, pca, L54,etc..y se cargan bien sin ningun problema. utilizo PCIN para la comunicacion con un ordenador win98 y esta configuracion 1200bd, 7bits, par, 2 stop, en el cnc 5011;11000100. 5013;11000100. 5016;00101000. Ojala alguien me pueda ayudar
    Jun 2018
    20
    +905357221418
  1. Chiron fz12w error
    By saeed_niknami in forum SIEMENS -> GENERAL
    Last Post: 02-14-2023, 06:30 PM
  2. Chiron FZ12W High speed Siemens 810m error codes
    By efret in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-15-2022, 08:36 PM
  3. Sinumerik 810m GA3 parameters. (Chiron FZ12W high speed)
    By mlinkadelsol in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 11-13-2017, 04:45 AM
  4. Chiron FZ12w Fanuc 21i
    By singist42 in forum Fanuc
    Last Post: 02-22-2014, 08:56 AM
