585,987 active members*
4,623 visitors online*
IndustryArena Forum > CAM Software > Vectric > Engraving Memorial Plaques
    Jul 2017
    Unhappy Engraving Memorial Plaques
    Needing help/guidance on what type of engraving tool to use on 1.6mm thick material to create text on a memorial plaque for recycled plastic garden benches. Equipment used is a mini CNC. Plaque size is 102mm x 65mm.
    Apr 2004
    5737
    Re: Engraving Memorial Plaques
    What's the plaque made of?
    Andrew Werby
    Website
    Jul 2017
    Material is black plastic with silver laminate. Overall thickness is 1.6mm.
    Apr 2004
    5737
    I'd probably use a single or two-flute ball end cutter for that.
    Andrew Werby
    Website
    Apr 2009
    5516
    We used single edged engraving tools for sign plastics. You'll have to get your spoilboard as level as possible, and you should use a vacuum fixture of some sort. The machines we used had a depth stop collar that rides over the work piece via a spring-loaded spindle, because there can be variations in thickness.
  1. Bronze Vietnam Veterans Memorial
    By widgitmaster in forum Aspire
    Last Post: 12-07-2015, 02:38 PM
  2. Engraving Stone Memorials & Plaques
    By Tony Mac in forum Vectric
    Last Post: 03-09-2015, 11:15 PM
  3. machine tags (plaques)
    By spider in forum Engraving Machines
    Last Post: 07-19-2011, 06:04 AM
  4. wooden 3d plaques
    By woodman08 in forum Canadian Club House
    Last Post: 08-20-2008, 05:09 AM
  5. need help with veterans memorial
    By deth502 in forum Uncategorised CAM Discussion
    Last Post: 07-30-2007, 02:23 AM
