585,555 active members*
3,355 visitors online*
Results 1 to 6 of 6
    Aug 2008
    403
    Z Axis Moves One Direction
    Problem with Z AXIS pin 6 and 7 motor only runs one direction. Swapped drives problem stayed the same. Took the terminal block off A axis and Z axis Drives . Swapped them now z axis will move in both directions A now only one way. So the direction pin is not working. I am to assume my break out board is bad? Software is set z axis pin 6 and 7 A axis 8 & 9 .The software shows a change in direction, in the dro when pressing jog buttons .The system is a smooth stepper feeding a c-10 break out board. The motion is very smooth and quiet. It fixed my p-port problem or driver issue. I am also having a problem with limit switch input. But that’s for later
    Jun 2004
    6618
    Re: Z Axis Moves One Direction
    That is usually a sign of bad or no contact on a motor pin. Try another set of pins other than the two that you know are bad. It could be a bad solder on the BOB.
    Lee
    Apr 2003
    540
    You most likely already have but while you're at it, take a meter and re-check all of your cables. Not just for good continuity with each wire, but for a shorts between any two wires or to ground. Wiggle the cable as you check each wire to check for possible intermittent issues also.
    Aug 2008
    403
    My machine is using 4 gecko 320x drivers .They have a terminal block that can be removed with all the wires connected. So I removed the block and switched the Z axis block with A now Z works so that rules out a wiring problem encoder problem , motor or driver problem . It leaves the connection between the smooth stepper and breakout board or a problem with the smooth stepper or a bad C-10 break out board .I'm leaning toward the C-10.
    Aug 2008
    403
    Pic taken before all wiring was done.
    Jun 2004
    6618
    I have had several C10's go bad in the exact same manner.
    Lee
  1. Z axis only moves in one direction
    By mklotz70 in forum Hobbycnc (Products)
    Last Post: 05-06-2020, 03:55 PM
  2. Axis only moves in one direction - need help
    By BRobbins in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2016, 03:23 PM
  3. Axis moves both direction with the same jog key
    By knowlzy1824 in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 09:35 PM
  4. axis moves one direction. help
    By rs4race in forum Benchtop Machines
    Last Post: 01-26-2014, 10:20 PM
  5. Axis moves in same direction
    By mreitt in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2013, 01:32 PM
