585,977 active members*
3,741 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak SQT15-MSY (T-Plus Control)+ LNS QuickLoad Barfeeder
    Jul 2017
    We had to replace the computer in our Mazak QuickTurn and we are now having problems with our barfeeder. We recovered all of our parameters except for the R I parameters which are apparently not backed up. Now itt will not finish the top-cut program. The bar gets loaded but the chuck will not close. We get an error code on the barfeeder that says it's waiting on the chuck close signal and it just sits there. It will eventually error out on the machine as a 245 - Barfeeder Malfunction. Any ideas on what parameters we may be missing? Nothing on the barfeeder has been changed so we are pretty sure the problem is with a parameter on the QuickTurn.
    Apr 2016
    74
    Re: Mazak SQT15-MSY (T-Plus Control)+ LNS QuickLoad Barfeeder
    I would give mazak a call, they are very helpful over the phone.800-677-8311.
  1. Mazak barfeeder problem
    By kennyp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-12-2010, 04:43 PM
  2. Trouble using barfeeder with mazatrol T plus control
    By redfishoil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-03-2009, 12:59 AM
  3. Mazak Lathe SQT15 programing help
    By Machsol in forum G-Code Programing
    Last Post: 08-01-2008, 07:35 AM
  4. Replies: 0
    Last Post: 10-05-2007, 06:39 PM
  5. Mazak SQT18MS/ LNS Quickload
    By lovell110 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2006, 02:19 AM
