586,000 active members*
4,956 visitors online*
    Oct 2016
    23
    RFQ - Threaded adapter from 1.125" SS rod
    I am looking for a quote to make one of these from 316L. The top thread is metric 22 and the bottom thread is american 7/8. It would be great of you had a set of nuts to verify the thread when complete.
    Update - see next post.
    Oct 2016
    23
    Re: RFQ - Threaded adapter from 1.125" SS rod
    So I decided to add a hex to the design and a second variation to the order. The hex means it now requires the next size larger rod. (1.25" rod.)
    I have made an IGES and STEP file for each.
    Tolerances are what you imagine, except there is a conical surface at the bottom/inside that becomes a metal-on-metal seal. That fit and finish needs a bit more care.
    PS - The M22 thread is 1.5mm pitch, and the 7/8 thread is 14 tpi. As mentioned above, I would like to have it verified with a nut before it ships.
    Oct 2016
    23
    Job taken, thanks!
  1. Replies: 2
    Last Post: 07-10-2015, 02:18 PM
  2. What is a "motion adapter"?
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 04-12-2014, 12:39 PM
  3. Applying a "threaded" traction surface ?
    By tubeguy in forum BobCad-Cam
    Last Post: 11-21-2012, 05:47 PM
  4. Collet adapter from 1/4" to 1/8"...
    By alank2 in forum CNC Tooling
    Last Post: 06-15-2012, 01:40 AM
  5. 1/8" and 3/16" router adapter - web links Please
    By DeadTom in forum DIY CNC Router Table Machines
    Last Post: 08-30-2010, 05:32 AM
