Hello, new to FeatureCAM. I'm having trouble with a part that we do first op on the lathe and than transfer to the mill to add a bolt pattern on the face (standard 3 axis op) and on the radial profile (4th axis op).
First issue is, how do I define the feature done on the lathe op when I import my solid?
Second is setting a USC for the 4th axis op? My issue is it want to use the X0,Y0,Z0 from Solidworks as my coordinates and I can not work out how to define a new USC to use X as my rotating axis and set X0 to the face of the part.
