2 days ago I powered on my Haas mini mill and had several alarms going off, beeping, and auto shutoff all on startup. After doing some investigating on the computer I found that it was most likely the battery on the main processor board in the back of the machine. I have replaced that with the dual battery holder from haas and it has not fixed the problem.
Do I need to reset the parameters? If so, how is this done? I was not able to back up the machine because I couldn't get past the screen in the attached picture or clear the alarms.
There is a usb drive in the back of machine labeled "recovery information" Is this of any use?
Here are the alarms I am getting:
(not in any particular order)
272 - C Axis Motor Overheat
276 - C Axis Drive Fault
678 - TT Axis Drive Fault
250 - Prog Data Error
135 - X Axis Motor Overheat
119 - Overvoltage Fault
249 - Prog Data Begins Odd
177 - Overvoltage Shutdown
The machine is only 5 years old so I hope this isn't something catastrophic.
Any help or ideas would be greatly appreciated.
Ryan
