I have everything wired correctly and am able to pass all of the setup testing however due to my configuration I need to do what I will call a dry run with a lower voltage power supply. When I do this the power supply that is available to me is very low on amps (1.3A). I get a tiny bit of movement and the drive shuts off. When I remove power and reapply power (not the power source power but actual power for the drive) it fires right back up. I am thinking this is happening due to lack of voltage with the temporary power supply but wanted to get input and advice before I hook up the full size power supply and test with that which may cause damage to the machine. Thanks in advance.
