584,871 active members*
5,253 visitors online*
IndustryArena Forum > Hobby Projects > Gunsmithing > Engraving machine in use for gunsmithing and manufacturing
Results 1 to 6 of 6
    Jul 2017
    Hey all,
    Just trying to see if anyone had made or bought an engraving machine for this purpose. I am needing it to mark 80%, hand guards, jewelry if need be, something with fine detail. Thanks
    Jon
    Jul 2017
    Re: Engraving machine in use for gunsmithing and manufacturing
    my I ask what are you trying to mark on your 80%
    Jul 2017
    10
    Yeah I made the mistake of buying a Chinese 6040 CNC router with the 2200 w spindle motor. And it is the wrong machine. my friend has a Tormach and it does all the engraving and CNC work wants done. Or you might be better off with a fibre laser,, much better for carving intricate designs in metal
    Jon[/QUOTE]
    Oct 2017
    27
    Quote Originally Posted by rokk View Post
    Jon
    [/QUOTE]
    I made an adapter to hold an pneumatic pencil grinder in my cnc spindle. It holds a 1/8 tool and turns over 50,000 rpm. I use f-engrave to generate g-code for text like the sn, "fire," "safe," etc. It also does graphics, but my machine doesn't have buffered input so I need to break graphics into multiple files. I prefer the 20 degree 0.1 mm v-bit for a fine line.
    Jul 2016
    660
    You mean this one?
    or this one?
    Jul 2016
    660
    Jon
    Your CNC machine is far more superior on the one I used, I only used a 1500W spindle on a 6040, but I can make any parts I want on it, my only edge to you is I custom sharpened my carbide tool bits and I programmed my tool paths in a custom CAM process im running my spindle @ 24K RPM all the way.
  1. Mobile Manufacturing Unit #1: LaserPod by Stone Design. Engraving on the streets.
    By stonedesigla in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-07-2017, 12:43 AM
  2. laser engraving machine ,engraving machine,cnc router
    By Tongxing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-22-2015, 03:40 AM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
