585,997 active members*
4,844 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > I need advice on this design. EG mill head with spindle.
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jul 2014
    215
    Re: I need advice on this design. EG mill head with spindle.
    Quote Originally Posted by WolfmansBrother View Post
    for scale, that spindle is about 240mm. the X axis is about 600mm.
    That mill looks a little more robust than I originally envisioned. I think it will work for a small hobby machine. One thing I would do is mount the motor for the spindle on some riser in that square cutout section on the top. This will put the mass of the motor closer to the column and if it's filled with EG it will make a good vibration dampening mount for the motor. You may also wish to consider beefing up the base and the bottom of the vertical column to add some mass and stiffness. It need not take up much extra space but it will improve the machining quality.
    If you have access to some surface plates and a mill you can get it pretty square. You can machine the parts very even and square and then use bolt together construction and then pour the EG in there.
  2. #22
    Jan 2016
    14
    Quote Originally Posted by Hezz View Post
    I can always make it thicker fairly easily. Changing the shape will be more difficult though as it is really easy to bolt that mold together rigidly. That way when I vibrate the mold it won't shift.
Page 2 of 2 12
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. Swivel head for a R8 spindle on a bench top mill
    By lilricky2 in forum Benchtop Machines
    Last Post: 09-06-2007, 05:18 AM
